Sponsored by: Kumho
Abs
Old Mar 24, 2007 | 01:45 PM
XylemXorro's Avatar
XylemXorro
Abs
Is there a way to tell if the ABS unit is bad? I have read through some threads and a humming sound was all that was listed. Is there a sure fire way? The light does stay on a little longer than the rest, but it eventually goes out. After installing a new water pump about three days ago (w/ the $35. thermastat), my funds are a little low now.
2000 X 7.3
Old Mar 24, 2007 | 01:53 PM
Lazy K's Avatar
Lazy K
Find a slippery surface, preferably isolated, and apply brakes firmly. You should feel a vibration thru the pedal as the ABS cycles the brakes.
Old Mar 24, 2007 | 02:01 PM
XylemXorro's Avatar
XylemXorro
Well, right now the pedal seems to press down about an inch then jump back up (while still pressing down).
Old Mar 26, 2007 | 01:31 PM
Lazy K's Avatar
Lazy K
Hard to say from your description. However if you brake hard on a slippery surface and your ABS is NOT working then you will get lockup. Usually the rear wheels will lock and skid easily followed by the front under severe braking. If the ABS is working then under the same conditions you should come to a stop without any wheels locking up and you should feel a rapid pulsating thru the brake pedal as the ABS works. I can assure you that on a wet or loose surface under braking you will soon know if the ABS is NOT working.
