TBC Fault Code
Old Apr 29, 2017 | 10:29 PM
phatboy7's Avatar
phatboy7
TBC Fault Code
Just bought an '05 with the trailer brake controller built in and as soon as I drove away from the dealer a TBC fault came on as well as a trailer disconnected, even though there's no trailer. Any ideas on where to begin other than having the dealer look at it?
Old Apr 30, 2017 | 01:01 AM
87crewdually's Avatar
87crewdually
Inspect the condition of the inside of the 7 blade RV plug receptacle. Also check the harness for starters.
Do you have an OBDII Bluetooth elm 327 adapter? If so you can buy the $5 app Forscan lite and do a diagnostic readout. Below is a screenshot of the pids you'll be able to check to make sure everything is functioning.
Old Apr 30, 2017 | 01:31 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
My experience, if the trailer plug looks good, no obvious damage, then the TBC Controller is junk.
Either replace or have it sent in and repaired.
Josh
Old Jun 14, 2020 | 12:33 PM
SLewis1's Avatar
SLewis1
1st check all the trailer associated fuses.
gogoat
2009 - 2014 F150
May 10, 2019 12:43 PM
blackgold50
All Things Towing
Jul 31, 2014 05:11 AM
Leonandlisa
6.7L Power Stroke Diesel
Mar 31, 2014 01:45 PM
Tattie Tam
May 25, 2011 07:37 AM
BKing
Oct 6, 2007 01:10 AM
