Ping during acceleration
Old May 6, 2017 | 04:44 PM
  #31
'89F2urd's Avatar
'89F2urd
Fuel filter first, confirm you aren't bleeding off pressure between tanks
Old May 6, 2017 | 04:48 PM
  #32
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
I installed a Motorcraft FG800A fuel filter 3 days ago. It accelerates better but it still pings with 87 octane.
I'm 99% sure that the anti drainback/check valve in the front tank is failing, I once had the rear tank on and it did fill up the front tank. I know there is an updated pump that fixes this issue but haven't gotten around to dropping the tank(s).
Old May 6, 2017 | 04:53 PM
  #33
'89F2urd's Avatar
'89F2urd
I'd start with replacing the front tank pump then, it's easier to do than the rear, and you already know it's failing
Old May 18, 2017 | 08:19 PM
  #34
Da_Lariat_Chariot
Ok guys, time to bump this, I have an update. I checked the wiring for both fuel pumpsand found the connectors were in need of some TLC. I cleaned them both off best I could and reinstalled the connectors. Best fuel pressure I can achieve is between 35-40 psi while driving on both pumps. I've been running 91 octane as a band-aid but guess what? IT STILL PINGS slightly. I'm stumped ...
Old May 19, 2017 | 01:15 PM
  #35
'89F2urd's Avatar
'89F2urd
Without going through the thread, have you checked pcv valve?
Old May 19, 2017 | 04:14 PM
  #36
Da_Lariat_Chariot
got a brand new Motorcraft valve about two months ago.
Old May 19, 2017 | 05:57 PM
  #37
'89F2urd's Avatar
'89F2urd
Pull your plugs and inspect them for one that is white, with everything else working properly, that's where logic points (an injector not flowing properly). I just went through that on my 97
spreng37
Oct 25, 2014 02:28 PM
dzjammer
20
Mar 19, 2014 11:39 AM
bigjonv
Nov 25, 2012 12:36 PM
RatRodF150
Sep 6, 2012 03:25 PM
