Ping during acceleration
Old May 3, 2017 | 01:11 PM
jas88's Avatar
jas88
You need to make sure your EGR is functioning.
Old May 3, 2017 | 06:38 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Last year I installed a new BWD EGR valve, reused the sensor and checked the vacuum lines to it. I have never had an EGR code come up since I've owned the truck.
Old May 3, 2017 | 07:58 PM
vjsimone's Avatar
vjsimone
Failed Knock Sensor, or Wiring?
Is your timing advancing during acceleration?
Rich or Lean? Measure pulse duration at the Injectors.
Inputs to the EECM triggers Rich/Lean commands.
Old May 3, 2017 | 09:45 PM
Da_Lariat_Chariot
I actually found some factory original Ford knock sensors, I ordered one yesterday. Theoretically could I try accelerating with the SPOUT disconnected to see if the timing is being advanced too much?
Old May 4, 2017 | 04:56 AM
'89F2urd's Avatar
'89F2urd
You haven't checked fuel pressure yet????
Need to check it under load. Engines will make gobs of power just before detonating themselves to death, so the "pulls good, fuel press must be good" test is not a good one. Check the fp!
Old May 4, 2017 | 04:56 PM
vjsimone's Avatar
vjsimone
Be advised, Knock Sensors are Engine Size Specific, and year specific. They are different frequencies...
I'm with '89F2urd, Fuel Pressure should be checked up front......
Old May 4, 2017 | 04:59 PM
vjsimone's Avatar
vjsimone
I think the Timing stays @ 10 deg btdc, or where ever you have the Base Timing set when you accelerate with the SPOUT out.....
Old May 5, 2017 | 12:09 AM
Da_Lariat_Chariot
Ok got a fuel pressure reading. 40 psi when KOEO, 35 psi running. No issues there.
Old May 5, 2017 | 01:13 AM
vjsimone's Avatar
vjsimone
You could also set you Base Timing to 8 deg, and see if that effects the pinging.
Old May 5, 2017 | 02:59 AM
'89F2urd's Avatar
'89F2urd
Did you check it under load while driving?
Old May 5, 2017 | 12:37 PM
Da_Lariat_Chariot
Doesn't dip below 30 on hard acceleration.
Old May 5, 2017 | 12:56 PM
yardbird's Avatar
yardbird
Try these things...
Put a block off plate between the EGR and intake and try that.
Back up the timing some more until the pinging stops. See if the engine power is where it should be with that. With a 302 you could have a worn timing gear, but still have decent vacuum. To check to be sure, take the distributor cap off, then bar the engine back and forth and see how much you have to move the crank before the rotor starts to turn.
Change the O2 sensor since that is one thing that will constantly change the richness of the fuel. Yours could be leaning out too much, especially after running cleaner through the engine. The crud released from that could have coated it.
Old May 5, 2017 | 02:24 PM
  #28
rla2005's Avatar
rla2005
The fuel pressure should rise under load. 30 PSI under load is way too low. Fuel pressure should never drop below the idle condition fuel PSI. At full load/WOT it should be in the 40-45 PSI range.
Old May 5, 2017 | 04:35 PM
  #29
'89F2urd's Avatar
'89F2urd
There you go. If it's not the cause of pinging, it's contributing. 30 is 8-12 psi too low.
Old May 6, 2017 | 02:51 PM
  #30
Da_Lariat_Chariot
So next thing would be check voltage at the pumps, make sure the wiring is in good shape. If that's all checking out fine then replace the pumps?
