Back Fire Question
Old Sep 4, 2012 | 09:13 PM
RatRodF150's Avatar
RatRodF150
Back Fire Question
i have 1978 f150 it backfires when i mash the gas or accelerate quikly, and when i start it, it will kindarumble and then die i have to hole the gas to get it to stay running on the first try, i check my wires they are in order and the plugs are all secure and wires as well. and the fuel filter is less than a year old, the exhuast manifold looks fine too, it has an Edlebrock 4BBL 16 series and intake manifold. What do i do
Old Sep 4, 2012 | 09:30 PM
ChiefM's Avatar
ChiefM
Sounds like the timing is way off, or a combo of timing and your carb needs adjustment. Is your vacuum advance hooked up to ported vacuum and not all the time time vacuum?
Old Sep 5, 2012 | 06:01 AM
fmc400's Avatar
fmc400
MSEE
Agree with ChiefM. Time for a tune-up.
Old Sep 5, 2012 | 07:59 AM
'78F250351m's Avatar
'78F250351m
My truck had a similar issue about a yr ago. After replacing the worn out fuel pump and having the Holley 4bbl rebuilt slightly my truck runs great. But i do agree with these guys the distributor timing could be the problem if theres lots of back firings.
Old Sep 5, 2012 | 01:43 PM
jim collins's Avatar
jim collins
Yep,timing first then carb. Just did my 302 yesterday ,timing was retarted way to much and i stuck a vac guage on the carb to set idle screws and got it a lot better. I'l find out the next time i take off in it, at least it don't back fire now and will keep running.
Old Sep 6, 2012 | 03:25 PM
NW 150's Avatar
NW 150
If it's not the timing, could need a bigger pump shot from the carb.
390ford1972
24
Jun 30, 2011 09:51 AM
8525ford
May 1, 2010 01:37 PM
PROSTOCK
29
Dec 19, 2005 12:45 PM
HES
Sep 1, 2003 05:45 PM
1ole4d
Aug 14, 2003 02:41 PM
