1978 - 1996 Big Bronco
do throttle body spacers realy work?
Old Sep 2, 2003 | 03:32 PM
COBRAjrb's Avatar
COBRAjrb
Question do throttle body spacers realy work?
i was thinking about puting throttle body spacers in my truck but didnt whant to spend the time puting them in,if they didnt make a diffence?are they easy to install i dont know?
Old Sep 2, 2003 | 03:58 PM
screwy's Avatar
screwy
they dont work.
Old Sep 2, 2003 | 04:14 PM
WhëëlMå1's Avatar
WhëëlMå1
I might have gained an iota of power, but definately not worth it! Plus, at certain rpm ranges (on mine at least), they gave off a definite whine from the air passing through it. Save your money and help offset that gas bill .
Rich
Old Sep 3, 2003 | 06:00 AM
94 XLT White/ Silver 302's Avatar
I bought a poweraid spacer plate for my 94 with a 302 engine. I have been very pleased with the mid range performance increase, as far as a gas mileage I haven't seen any improvement.
Old Sep 3, 2003 | 09:15 PM
Capone's Avatar
Capone
Hmmm, the theory is that the spacer plate creates a longer run between the ruber hose and the intake throats...well, unless your truck got wider and the air cleaner moved out further, you won't really get that air velocity the TB spacer people promise. The place where you want power increase is at the
low end torque range....and good throttle response. The end result, aluminum ports replacing rubber air hose. looks good, but you'd be better off wrapping the air hoses from air cleaner to TB to lower intake charge temps.
Old Sep 7, 2003 | 02:44 PM
The purpose of the spacer plate isn't to create a longer run between the ruber hose and the intake throats, the airaid spacer with it's helix thread in the spacer causes incoming air to spin in a vortex pattern. The spinning action continues into the manifold runners and into the combustion chamber to help the air and fuel thoughly mix to create an improved combustion process.
Like I said before it works on my 302 in the mid range rpm's. My brother has installed one on his 1995 F150 with a 302 and received the same results. If you want one for increased gas mileage save your money.
Old Sep 7, 2003 | 03:47 PM
Capone's Avatar
Capone
it will work a bit on the mirange to the top end...only...
the spacer would work better with a carbed setup versus the EFI system, due to the proximity of the injectors to the intake valve...
As far as applying this to a truck, we do most of our work on low end torque, so this app is not really applicable for the intended use.
you'd gain much more power with simply bolting on a set of JBAs or Bassani headers (thermal barrier coated)
good luck
superdutyduck
Jun 7, 2010 09:27 AM
shawn55
Modular V10 (6.8l)
13
Feb 16, 2010 12:26 AM
01redcrew
2004 - 2008 F150
24
Mar 1, 2009 11:50 PM
RobbieC
May 30, 2001 05:21 PM
paulg
May 25, 2001 05:19 PM
