Spontaneous window blowout
Old Apr 30, 2017 | 11:14 AM
GlueGuy's Avatar
GlueGuy
The outside temperature was 62°. So it shouldn't have been from an extreme temperature event. However, the window was facing the sun, and it was right about noon. When I picked the bits and pieces out of the frame, they were hot to the touch.
Took me about 2 hours to sweep up all the pieces and vacuum what I could. A whole bunch of the bits fell inside the door.
Made an appointment through our insurance company to get the glass replaced on May 10.
Ford warranty does not cover side glass past 12 months.
Old Apr 30, 2017 | 04:14 PM
soulpatch's Avatar
soulpatch
Originally Posted by miner999r
I was told later that first responders either carry a small device or even an old spark plug.
Here you go
Pretty standard for firefighters involved in rescue scenarios.
We had other tools but this was small and quick.
Old May 1, 2017 | 12:34 PM
Terryd91's Avatar
Terryd91
If in an emergency and the antenna has the little ball on the end of it snap the antenna off and hold it to the window. Pull the tip of the antenna back and let it slap the window, 9 out of 10 time its will shatter. Seat belt cutter is another must have for emergency too.
The glass could have had a hairline fracture in it you didn't even notice, and the pressure blew it out. glad no one was in the seat at the time!
Old May 1, 2017 | 08:22 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The front door windows are just like a windshield. Mine cracked when I visited Grand Tetons in March. $200 later it was replaced.
Josh
Old May 2, 2017 | 09:35 AM
GlueGuy's Avatar
GlueGuy
Originally Posted by soulpatch
Here you go
Never thought that a center punch would work for that. Good to know. The thing that I've seen is a combination window breaker and seat belt cutter. Pretty cheap at $6.
https://www.amazon.com/Towallmark-Seatbelt-Cutter-Breaker-Emergency/dp/B002AMAXNA https://www.amazon.com/Towallmark-Seatbelt-Cutter-Breaker-Emergency/dp/B002AMAXNA
Old May 2, 2017 | 09:42 AM
soulpatch's Avatar
soulpatch
Josh
They shouldn't be. They should be tempered and the front is laminated.
Old May 2, 2017 | 09:50 AM
xr7gt390's Avatar
xr7gt390
https://www.amazon.com/Towallmark-Se.../dp/B002AMAXNA
We have that same tool in all our cars. It's amazing how easy a window breaks using that device.
Old May 2, 2017 | 03:57 PM
mroberts8899's Avatar
mroberts8899
Ford most likely won't warranty it do to there is no way to prove if it was a defective glass since it is in so many pieces. Which is no ones fault. Ford is touchy on glass. They changed their policy and length of warranty on glass. Windshields went from 1 yr to 6 months on new vehicles.
Better call insurance copy.
Old May 2, 2017 | 08:14 PM
RigTrash601's Avatar
RigTrash601
Like others, I'd say look out for a sniper, albeit one that has poor aim
Sorry to hear this, I'd imagine it will most definitely be an insurance claim, never heard of a manufacturer stepping up on a window warranty like this.
Good luck my brother!
Old May 4, 2017 | 07:55 PM
Bullitt390's Avatar
Bullitt390
???? As I said the front Door window is laminated like a windshield. Hence why it is called Acoustic Glass.
Josh
Old May 4, 2017 | 08:58 PM
soulpatch's Avatar
soulpatch
Josh
Well, I'll be damned. Don't get all indignant now.
Learn something every day!
I should always defer to a guy with damn near 14,000 posts!
I think of the hundreds of times I've been on vehicle extrications and I've never seen that.
However, I have been retired for almost 5 years so things change in the vehicle world and I see things have changed in the automotive world.
Heck, as soon as it's daylight here I am going to look at what I have in my truck!
Old May 6, 2017 | 05:06 AM
Dim Sum's Avatar
Dim Sum
Had the same thing happen to a work F-250 I had. Was sitting still at a stop light and the glass shattered.
My first reaction was to have everyone check to see if they were shot. Since it was a government vehicle, no help was asked from Ford...
When you're close to the event, it does surprise you.
Old May 6, 2017 | 01:35 PM
  #28
GlueGuy's Avatar
GlueGuy
Been running around with a taped-up hunk of cardboard in the hole for the last week. The appointment with the glass place is not until next Wednesday. I'll be happy when it's been replaced, and I hope it never happens again.
It makes me very leery about leaving the truck in any parking lot.
Old May 6, 2017 | 02:44 PM
  #29
RigTrash601
I can only imagine, where are you getting it replaced, Ford dealer or a glass shop?
Old May 6, 2017 | 03:23 PM
  #30
GlueGuy's Avatar
GlueGuy
Ford basically said "Nope. Not warranteed. Go away kid." So I called my insurance company, and they set up the appointment for me with Safelite. We've dealt with them before. They are quick, efficient, and generally don't make a mess.
