64 F-250 Engine Removal
Old Apr 28, 2017 | 11:36 AM
Driver1337's Avatar
Driver1337
I am planning on doing a engine swap for another 292 out of another truck. Where would be good mounting points to put in studs for the chain and I am not planning on taking the transmission out.
Old Apr 28, 2017 | 03:40 PM
resonateur's Avatar
resonateur
If you have a carb lift plate you can use the carb mounting studs. Although proven effective, I'm personally more comfortable witht the larger bolts that mount the intake to the heads....not the short ones at the back and not the center ones that hold the cups, but one in each of four corners. That should give you a pretty stable vertical lift without the trans.
Old Apr 29, 2017 | 11:15 AM
daveengelson's Avatar
daveengelson
Suggest beg, borrow, or rent a 'load leveler', particularly if removal requires tilting the engine to clear the radiator support. If so, agree with resonateur attach to the intake or exhaust manifold bolts using spare bolts and large heavy duty washers?
Old Apr 29, 2017 | 04:25 PM
Driver1337's Avatar
Driver1337
Thank you guys
tater_51
Mar 4, 2013 06:35 PM
78bigunns
Mar 19, 2007 01:19 PM
John_1953
Mar 31, 2006 12:34 PM
gibsonj
Garage & Workshop
Nov 2, 2005 08:26 AM
ZombieSlayer
Apr 2, 2003 11:30 PM
