Engine Pulling Bolts
Old Mar 26, 2006 | 10:42 AM
John_1953's Avatar
John_1953
What size of bolts should I use when I yank my engine? According to Steve Christ I should use a couple of bolts on the end of the heads. What size are those holes? Do others ust those, or just use a couple of the manifold bots?
Old Mar 26, 2006 | 11:17 AM
fordraceboy's Avatar
fordraceboy
a carb lift plate works really nice.... if not just use a couple of the manifold bolts- i believe they're 3/8"....
Old Mar 26, 2006 | 07:08 PM
John_1953's Avatar
John_1953
Thanks. I was wandering through O'Reillys and saw one of those carb plates. At $10 I decided to try it out. I should be pulling the engine next weekend after I get my cab off.
Old Mar 28, 2006 | 12:45 PM
bertha66's Avatar
bertha66
Myself I use the intake bolts, the ones on each side of the carb, with the carb off.
Old Mar 31, 2006 | 12:34 PM
jor's Avatar
jor
John,
If you use the carb plate pulling method, be sure you do not use your carb mounting bolt. Pull them out and replace them with grade 8 bolts.
jor
