Metal Shavings
Old Apr 27, 2017 | 07:07 PM
Redneckrucker16's Avatar
Redneckrucker16
Metal Shavings
SO the fun begins,
I finally got around to changing all my fluids last weekend, front and rear diff, transmission, transfer case, fuel filters, all of it. I also replaced all my covers with the magtech covers. For you naysayers that dont think the provide additional cooling, i dont care, they look cool lol. The wife and i went to bristol last weekend for the race and i hauled our camper and everything was fine. Noticed quite a bit of fluid on my left rear shock on monday and figured i just blew the shock out. So i checked the rear diff today for ****s and giggles and ill be damned... For those who dont know, the magtech covers come with a dipstick with a magnet on the end. So when i pulled it to check the fluid it was covered in shavings. Not to mention the fluid was nasty even though its only a week old. So i guess my real question is, is it time for a new differential setup or should i just check it again in a week and see if maybe i get lucky and theres no more metal?
Old Apr 27, 2017 | 07:30 PM
BLADE35's Avatar
BLADE35
What fluid was put in
Old Apr 27, 2017 | 07:34 PM
Redneckrucker16
75-140 synthetic ls
Old Apr 27, 2017 | 07:42 PM
BLADE35's Avatar
BLADE35
Originally Posted by 87crewdually
Front Differential F-250/350
SAE 75W-90 Lubricant
Quantity: 3.8 pints
Rear Differential F-250/350 (10.50 inch axle)
SAE 75W-140 Synthetic Rear Axle Lubricant
Quantity: 6.9 pints
If you have a limited slip rear differential you also need 8 ounces of Additive Friction Modifier C8AZ-19B546-A unless you use a synthetic that declares it's not necessary such as Valvoline or Royal Purple.
If you google " 52148 seal " you'll see many leads. For whatever reason the original motorcraft #2C3Z-3254-AA isn't showing. Spicer and national both offer the seal.
Friction modifier??
Old Apr 27, 2017 | 08:20 PM
wedge542's Avatar
wedge542
Most synt today already has the friction modifier in them, did you see any metal when you drained it the week before?
Old Apr 27, 2017 | 08:31 PM
Redneckrucker16
The new fluid already had friction modifier in it. I didnt notice and shavings when i changed it last week although it was pretty dark and a little thick. I just figured it was because no one had ever changed it.
Old Apr 27, 2017 | 08:33 PM
Mustangman68's Avatar
Mustangman68
Any limited slip differential or "posi" needs a friction modifier. Last time I did the rear end on my Mustang I accidentally forgot to add it in and started hearing (and feeling) a clunking noise and then looked on the shelf and realized what I did. I did a full swap on fluid again. I have magnets on the housing and noticed a little metal, but after new fluid with additive all is well and runs fine. I always just buy the friction modifier separate and add it in, I've heard of issues with fluid that supposedly has adddative already and just never trusted it.
I think you should be good if you do another fluid change with the additive.
Old Apr 27, 2017 | 08:34 PM
wedge542's Avatar
wedge542
Any case its there now, bearings,cups,gears,something about to come apart.
Old Apr 27, 2017 | 08:41 PM
Redneckrucker16
well there goes another 150 bucks in fluid.
Old Apr 27, 2017 | 08:44 PM
wedge542's Avatar
wedge542
That would be alot cheaper than building the diff, good luck.
Old Apr 27, 2017 | 08:46 PM
Redneckrucker16
lol thanks, ill change it out tomorrow and give it a couple days and check it again
Old Apr 27, 2017 | 08:54 PM
wedge542's Avatar
wedge542
Was the shavings large or just a dust like on the magnet?
Old Apr 27, 2017 | 09:17 PM
87crewdually's Avatar
87crewdually
Pull the cover and with a pry bar check horizontal play. If there is any play then the ring gear carrier bearings are disintegrating. Also check pinion movement for a failed pinion bearing.
The metal is coming from somewhere. The LS has fiber disks. Also if you used full Syn (75w-140) it already has the friction modifier in it. It is not needed.
. Here's a failed carrier bearing that I caught just before a 1300 mile trip double towing my 5er and flatbed trailer.
Old Apr 27, 2017 | 09:30 PM
Redneckrucker16
I put hands on everything when I swapped the cover last week. The backlash seemed right, though I don't have a gauge, all the teeth looked good on the ring, I did notice what looked like a gouge in the limited slip assembly but don't know what would even cause that lol.
Old Apr 27, 2017 | 09:31 PM
Redneckrucker16
no chunks or flakes or anything like that just a fine dust but enough to make me worry.
