Long Haulers
Old Apr 27, 2017 | 03:27 PM
bowler304's Avatar
bowler304
Long Haulers
I have the truck in my signature and we have a 35' travel trailer (8K lbs), we are going to Alabama from Texas about a 10 hour drive. This is my first long haul with the trailer, I normally keep our camping trips under 2 hours from the house, so I don't have to find a gas station to fit 21 feet of truck and 35' of trailer. Still a bit nervous but I will just find all the Luv stations along the way.
Any tricks to taking the TT this far? Should I do anything extra to the truck before going? I already check oil, tires, fluids, etc...
Little nervous give me some hints to calm my nerves.
Old Apr 27, 2017 | 03:45 PM
Johnpsz's Avatar
Johnpsz
So, let me calm your nerves. I have gone cross country 5 times in my old truck, and plan a 7,300 mile trip this summer in the new truck towing our 36' 5th wheel. As for Gas stops, you may want to look for Flying J truck stops as they normally have RV lanes separate from the normal vehicle or big rig lanes, and should have both Gas and Diesel pumps on them. Also, don't assume, unless you are really trying to, that you will make that 10 hours of driving in 1 day. 10 hour of drive time (like based on google maps) will take you probably 12-14 hours between fuel stops, bathroom/meal breaks an so forth. I will attach a PDF of one of the legs of our summer trip, to show you that we break a day of driving into 8 hour or less chunks, and even though from my sister's place in Delaware to Charleston SC is about 10 hours, we have an overnight stop planned in Dunn, NC at a truck stop for a night.
Old Apr 27, 2017 | 04:00 PM
Sparks123's Avatar
Sparks123
I found it helpful to check the trailer and truck brake temps with one of those handheld infra red temp guns whenever I stop. I know some people carry a 5 gallon can with spare fuel.
Old Apr 27, 2017 | 04:41 PM
petei's Avatar
petei
Did you check the grease in the bearings you suppose to pack them every 2 years or less.And for the gas station don't go to truckers station time consuming and more expensive.
Old Apr 27, 2017 | 07:16 PM
Habemus Quattro's Avatar
Habemus Quattro
What I do when traveling this way is to plan out my stops ahead of time, using Google maps / satellite view to see what the ingress/egress and maneuverability looks like at stations around where I know I'll need to stop. When we stop for a meal, a rest, or even a fuel break, I will start researching my next fuel stop. Then there is usually no drama.
Flying J and TA have generally been good places for me to look. Some Pilots and Love's can be a little on the small side. It really just depends so the satellite view is golden. Don't forget to look for your typical Shell and Chevron type stations. Some of them can be very accommodating to RVs.
Old Apr 27, 2017 | 07:37 PM
Uzumati's Avatar
Uzumati
Where in Bama are you coming to? You will find a lot of non truck stop stations have plenty of room for a long trailer here.
Old Apr 27, 2017 | 07:50 PM
Xwild's Avatar
Xwild
Key thing - don't wait until you NEED gas to start looking for a station. Fill up at 1/2 a tank, and that way if you come up on a station that just is a pain to get into, you roll on by and find a different one without having to worry.. And most truck stop style stations will fit you just fine.. FLying J, Loves, etc.. Pick up a Good Sam campground guide.. believe they have gas station info..
Old Apr 27, 2017 | 08:49 PM
AMXDREAMER's Avatar
AMXDREAMER
You should be able to show fuel stations on the navigation. Pick one of the major truckstop type vendors along the interstates and you should be good!
Old Apr 27, 2017 | 09:31 PM
bushpilot's Avatar
bushpilot
what are you nervous about?
I AVOID the truck re-fueling island, mostly cause they foam/flow too fast for our 150 gallon capacity. If you use Petro/Flying J RV islands (as we do) you'll get the cash price even when you pay w/ plastic.
if you use the truck island - the cash price MEANS you must go inside, deposit green/cash - fuel up and then go BACK inside to retrieve your overpayment.
We run/tow a 65' combined rig all over the place - Houston to Virginia is a regular run and I've never had a problem getting in and out of the RV islands.
Old Apr 27, 2017 | 09:54 PM
RFM's Avatar
RFM
Beautiful setup
Old Apr 27, 2017 | 10:04 PM
bushpilot's Avatar
bushpilot
Originally Posted by RFM
Beautiful setup
thanks!
our long bed crew cab '04 (leaf spring / diminished turning radius) pulled our stuff well and I NEVER had a maneuverability issue (but then I'm NOT afraid to use reverse)....
as I always said....better to back up than TEAR (stuff) up...
Size:  31.8 KB Name:  770-Horse-COMBINED.jpg
Old Apr 27, 2017 | 10:32 PM
wb6anp's Avatar
wb6anp
Originally Posted by bushpilot
thanks!
I am SOOOO Jealous of your second pic, that is my all time favorite car. lol
Old Apr 27, 2017 | 10:34 PM
72GTS's Avatar
72GTS
^^^^ Love the COBRA on the trailer.
Old Apr 28, 2017 | 08:04 AM
Capt. Ted's Avatar
Capt. Ted
My boat, on the trailer has a height of 13'10". I'll be towing it from Lake Erie to the Gulf of Mexico. Has anyone used the apps giving bridge height?
I'll also have a 63' oal, and 10'4" wide. I plan on getting oversize permits. We could use any tips on these long hauls.
Old Apr 28, 2017 | 08:33 AM
bowler304's Avatar
bowler304
We do yearly maintenance on our TT and this is part of the checklist, so we should be good.
Joe Wheeler Lake, my father in law has a boat out there so it should be a neat trip for the family.
