1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2011 F250 Instrument panel issues
Old 04-27-2017, 02:38 PM
ShipkaRob's Avatar
ShipkaRob
ShipkaRob is offline
First time poster here hoping you guys can assist me before I break down and have to go to a shop. I did search but only found this on older models nothing in the 2011-2016 series of trucks.
I have a 2011 F250 v6.7 and have been very happy with it. Two days ago when my wife was driving the instrument cluster(spedometer to 0, tach to 0, display blank), radio, blinkers all died then came back During this the fan would also come on at high even if it had been turned it off. It happened several more times on her drive. Then started getting stabil track alarm and then the battery light would come on. I measured both batteries disconnected and got 12.5v on each, cleaned the terminals put them back on and got ~14.5v when running. I took it for a drive and at first it was fine but after 10-15 minutes the same things started. Truck never lost power, seemed to run okay, just no gauges, active alarms.
Im worried driving it like this may cause issues with the truck but also will be towing a 35' fifth wheel again soon and worried about loosing control with it on.
Looking for any suggestions on diagnostics I can do my self before taking it to the dealer. I had an electrical issue on an old vehicle and spend a fortune to never get it fixed, hoping to avoid that again.
Old 04-27-2017, 04:22 PM
seville009's Avatar
seville009
seville009 is offline
I'm no mechanic, but as a guess it almost sounds like you have a loose ground wire or something like that. Just go around checking all of the connections you can see. There's supposed to be a plug down by yhe emergency brake pedal i think that has bern mentioned in various threads as coming loose and causing similar conditions.
Old 05-01-2017, 10:30 AM
ShipkaRob's Avatar
ShipkaRob
I have tried that but haven't found anything. Expecting a bad ground as well, just not sure where to look for all the most likely ground locations.
Old 05-01-2017, 05:48 PM
scottscott's Avatar
scottscott
scottscott is online now
Common problem. There is a wiring harness connector attached to the parking brake pedal bracket. The jarring action of releasing the park brake play havoc with this connector. Cure is to remove the connector from the bracket & tie wrap it up out of the way. You may have to wiggle the connector some to get it firmly seated.
The 13 I drive was doing what you described regularly, hasn't done it in 80,000 miles since I moved the connector. Do some searches for crazy dash or similar to find more threads & detailed fixes.
Dealers seem to be clueless about this problem.
Old 05-10-2017, 08:48 AM
Bandguy's Avatar
Bandguy
Bandguy is offline
Steven Trottier
6.7L Power Stroke Diesel
06-15-2020 07:32 AM
bradxray
18
11-17-2019 08:45 AM
Swamp_Yankee
6.2L V8
10-29-2018 08:12 PM
Rob89
16
05-15-2018 10:55 AM
RazorRay24
11-28-2017 02:45 PM
Quick Reply: 2011 F250 Instrument panel issues
