Black Oil Filter
Old Apr 27, 2017 | 12:52 PM
saskowner's Avatar
saskowner
Black Oil Filter
My truck finally arrived at the dealer yesterday so one of the things I checked out was if the oil filter was leaking like others have reported. I was very surprised to see that the filter was black instead of the usual white. Is this something that Ford has changed recently? The good news is that I didn't see any leaks.
Gary
Old Apr 27, 2017 | 01:00 PM
bikerman5345's Avatar
bikerman5345
That means it is the original factory filter. Nothing odd about it.
Old Apr 27, 2017 | 02:20 PM
System's Avatar
System
Prolocutor
Yep, the one from the factory comes black. I always figured it was so they could tell if someone did their first change yet. They used to do the same on the engine compartment fuel filter too. There was a dead end third hose connection on the factory one that wasn't on the Motorcraft replacement. It was always a good tell to see if the truck was ever maintained.
Old Apr 27, 2017 | 04:33 PM
69cj's Avatar
69cj
Sorta like the plastic plugs that were on the c6 tranny from the factory. When the dip stick tube was installed they would just knock the plug into the tranny pan. If a tranny issue surfaced they could tell if the filter and fluid had been changed by the presence of the plug.
Old Apr 27, 2017 | 11:06 PM
saskowner's Avatar
saskowner
Thanks for the info. The black filter made it real hard to notice if there was any oil leakage on it. Glad to hear it is not a permanent change.
Gary
Old Apr 28, 2017 | 11:38 PM
BII Plow Truck's Avatar
BII Plow Truck
Ford still does this!
Old Apr 30, 2017 | 06:52 PM
System's Avatar
System
Prolocutor
So just came across some new info about the black factory filter vs. the white Motorcraft unit. According to what I read... and it was on the internet so it must be true...LOL... the black factory filter is made by Champion Labs who also make the Mobil 1, Bosch, and K&N oil filters and is of higher quality. The Motorcraft filter is made by Racor. Interesting find and explains the color difference.
FordTruckEnthusaist
Sep 10, 2012 09:36 PM
tolliewolly
6.7L Power Stroke Diesel
26
Jun 6, 2012 06:07 PM
Mudd460
2009 - 2014 F150
Feb 12, 2011 06:22 PM
murph1
Modular V8 (4.6L, 5.4L)
Feb 14, 2010 05:03 PM
cocot
Oil & Lubrication
Oct 23, 2003 07:57 PM
