oil filter
Old Feb 12, 2010 | 04:46 PM
murph1's Avatar
murph1
oil filter
I have just changed the oil on my 2010 4.6...first oil change...I purchased a filter from the dealer...when I changed my oil I started to compare the filters..the one from the dealer and the one off the new motor..
just wondering why there is so much of a differance between the 2...
The original has much larger porting,the original has no idetification on it what so ever,its even made a little different when you look inside..
The filter from the dealer and other part stores are identical, so now I am very curious as to why the big differance...
any ideas..
hopefully a tech out there will know.
Old Feb 12, 2010 | 06:18 PM
MisterCMK's Avatar
MisterCMK
The factory oil filters are not the same as the Motorcraft ones.
Old Feb 13, 2010 | 04:54 PM
galaxie641's Avatar
galaxie641
Yep they are just blank bland filters, no reason to put anything on a filter that is put on at the factory.
Old Feb 13, 2010 | 07:21 PM
Moto Mel's Avatar
Moto Mel
I'm with Murph on this, I would want to know what the difference is and why. I would also want to know why the dealer sold me a filter that was not the same as the one that came on my truck from the factory. I would want the same filter even if it cost a little bit more.
My suggestion is that Murph contact the service manager at the dealership about this and if his explaination was not satisfactory I would then contact Ford Engine Engineering and ask for an explaination. Get a response in writing so if any warrantee problems arise you are protected.
Old Feb 14, 2010 | 03:01 PM
murph1's Avatar
murph1
this is a response from the 2009 and newer forum
the factory filter is manufactured from a different company than the Motorcraft in the parts stores.
Not positive but I think the factory filter is from Champion labs?
The Motorcraft is made by Purolator.
Old Feb 14, 2010 | 05:00 PM
Moto Mel's Avatar
Moto Mel
When I worked a Holman and Moody we used the Wix HD or HP filters and all the engines we recieved from Ford either came with them or were changede out by the people checking the engines in. NAPA sells the Wix filter and it would be very interesting if you would compare your old one to a Wix. To my knowledge we (H-M) never had an engine failure related to a Wix filter.
Old Feb 14, 2010 | 05:03 PM
Moto Mel's Avatar
Moto Mel
When I worked a Holman and Moody we used the Wix HD or HP filters and all the engines we recieved from Ford either came with them or were changede out by the people checking the engines in. NAPA sells the Wix filter and it would be very interesting if you would compare your old one to a Wix. To my knowledge we (H-M) never had an <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_15_0>engine</NOBR> failure related to a Wix filter. <!-- / message -->
<!-- controls -->
KC8QVO
6.7L Power Stroke Diesel
Jan 8, 2012 08:10 AM
murph1
2009 - 2014 F150
13
Feb 14, 2010 08:24 AM
da-bees
Dec 9, 2009 11:35 AM
loudford
Sep 10, 2009 10:57 AM
Gage2502
Modular V10 (6.8l)
16
Aug 7, 2006 07:11 PM
