Hydra chip & Lie-ometer
Old Apr 27, 2017 | 09:15 AM
bigreentruck's Avatar
bigreentruck
Recently installed PHP Hydra chip. Just about flipped out when I looked at the mpg on the lie-ometer. It went from about 12 mpg in town before to around 19 in the Daily Driver mode. Is that possible?
Going out of town Saturday and will do an actual calc. I'd be ecstatic if it's real.
Old Apr 27, 2017 | 09:22 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Nope. Not possible. Ignore the display from now on.
Old Apr 27, 2017 | 09:43 AM
F250_'s Avatar
F250_
I concur with cleatus12r. Hand calculate your mileage... it's the only reliable way to KNOW what's going on.
Old Apr 27, 2017 | 11:13 AM
andym's Avatar
andym
So you knew it was called the Lie-ometer and you still asked if it was telling the truth?
Old Apr 27, 2017 | 11:27 AM
Walleye Hunter's Avatar
Walleye Hunter
Old Apr 27, 2017 | 11:33 AM
F250_'s Avatar
F250_
Look... cut him some slack here... one can always be hopeful, right?
Old Apr 27, 2017 | 11:40 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
I really wish that I could write tuning that would actually give a seven mile per gallon increase simply because I would be one of the richest people on the planet at that point.
Old Apr 27, 2017 | 11:46 AM
F250_'s Avatar
F250_
Originally Posted by cleatus12r
I really wish that I could write tuning that would actually give a seven mile per gallon increase...
You, and everyone else who would pay for it!!
Old Apr 27, 2017 | 12:09 PM
Walleye Hunter
Has anyone ever tried writing a tune that would cut some injectors out at highway speeds and low load conditions? Or would the lack of fuel cause a reduction in cylinder lubrication?
Old Apr 27, 2017 | 12:15 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It's impossible to do with the hardware. Besides, have you ever driven one of these pickups with a bad valve cover harness? Running on fewer than eight cylinders does nothing more than max out the EGT and put your maximum speed at about 45 miles per hour. You will burn just as much fuel on 4 cylinders has you do on 8 to maintain the same road speed.... likely even more to overcome parasitic drag of the other cylinders.
Old Apr 27, 2017 | 12:20 PM
F250_'s Avatar
F250_
I've got one cylinder which doesn't fire until the oil gets warm enough to let the poppet begin moving again, and it's no fun driving the few minutes until it gets to temperature... not horrible, but just not smooth at all.
Old Apr 27, 2017 | 12:53 PM
The Brad's Avatar
The Brad
Shoot! If you'd start selling your tunes, you'd probably get rich! I'm running a DP F6, but I'd buy a Hydra just to try your tuning.
Old Apr 27, 2017 | 01:31 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
.......give it just a couple months.
At that point, I will no longer be an FTE member though.
Old Apr 27, 2017 | 02:36 PM
akcooper9's Avatar
akcooper9
Can I be first in line please?!
Old Apr 27, 2017 | 02:47 PM
Rikster-7700's Avatar
Rikster-7700
As long as you give us a link or something to find you, we will be good..... 😀
(Not that you won't be sorely missed in this and the other boards of course!)
Oh and if you would please add me to the list?!
