Fuel pump problem.
Old Apr 26, 2017 | 11:09 PM
Whit Justice's Avatar
Whit Justice
Fuel pump problem.
I have a 2000 f350. Lost power whole driving and won't start back up. I have checked all my fuses and relays several times. Have no power to the fuel pump. Tried running a hot wire straight to the pump and still nothing.checked my emergency cur off switch and there is no power there. Also my WTS light isn't coming on now. Tried checking the heater bowl and no power there. Any ideas or help would greatly appreciate it.
Old Apr 26, 2017 | 11:43 PM
Rikster-7700's Avatar
Rikster-7700
Are you sure you checked all the fuses? Especially #30?
Old Apr 27, 2017 | 12:22 AM
Whit Justice
Yes i have checked all of them under the hood and inside the truck.
Old Apr 27, 2017 | 10:03 PM
pirschwagon's Avatar
pirschwagon
No WTS light "usually" indicates the PCM is not getting power or, the PCM has given up the Ghost. Do you have reference voltage on any field sensors? That is a good indication the PCM is working.
As for the fuel pump, it should spin when power is applied. But you'll need to ground it as well. The PCM Ground Switches the Relay for Power. If you can get a Test Gauge, I would test the Pump again with 12 VDC.
Old Apr 28, 2017 | 04:02 PM
Bonanza35's Avatar
Bonanza35
Wait to start light out usually means fuel bowl heater shorted out.
Old Apr 28, 2017 | 05:51 PM
Rikster-7700
How did you check them? With a DVOM? Or just a visual?
Fuses can sometimes look good but still be blown....
Old Apr 29, 2017 | 03:15 PM
dn29626's Avatar
dn29626
Disconnect the harness (heater & water sensor) from the fuel bowl. Buy and install a new fuse in #30 slot.
Crank the engine and let us know if it starts running.
lamm72
Feb 25, 2017 07:55 PM
79rngr
1997 - 2003 F150
Jun 25, 2014 10:14 PM
adworden
Aug 27, 2013 11:45 AM
dn29626
Sep 11, 2010 02:33 PM
dslmechanic
13
Jun 25, 2009 01:22 PM
