PCM obd2 readings
Apr 25, 2017 | 07:57 PM
PCM obd2 readings
2001 4x4 excurain V10
There are no codes, but doesn't below data show right side O2 sensor is not working?
O2S B1 S1 (V) .115 to .84
STFT B1S1 (%) 3.1
O2S B1 S2 (V) 0.0
STFT B1 S2 (%) 99.2
STFT B1. 0 TO 3.1
LTFTB1. -7.8
STFTB2. -3 TO 4
LTFTB2. -1.6
Apr 25, 2017 | 08:04 PM
Your truck probably doesn't have a downstream O2 sensor so the scanner/software just zeros out the "reading".
Are you working on an actual existing problem or trying to create a new one?
Apr 25, 2017 | 09:01 PM
You are correct it does not have a down stream O2 sensor.
But it has 2 O2 sensors, one on left side and one on right side pre cat. I thought S1 would be side 1 and S2 would be side 2?
Apr 25, 2017 | 11:38 PM
Apr 26, 2017 | 03:59 AM
Quote:
Originally Posted by
rock2610d
Negative. B1S1 stands for Bank 1 Sensor 1. For the other side, it's B2S1 (Bank 2 Sensor 1). In your case you have no rear O2 sensors so readings for B1S2 and B2S2 are not relevant. And if you're wondering, for the 6.8 V10 bank 1 is the passenger side and bank 2 is the driver's side
Apr 26, 2017 | 06:32 AM
Ditto ... "Bank 1" is the one with cylinder #1. I think this is for all vehicles, not just Fords.
Apr 26, 2017 | 08:18 AM
Thanks, appriciate your help.
So I have readings for only 1 O2 sensor?
Obd2 shows no other O2 readings for second sensor. How do I know the readings on both sensors?
I have no B2S1 O2 data on my obd2 device.
No heading to even look at for any results.
Paid $150 for this crap obd2 reader, logger and it can't evendors give me ABS info. Now it can't log both O2 sensors.
Apr 26, 2017 | 08:46 AM
Can you put custom PIDs in the logger?
Can you contact the manufacturer and ask them? Sometimes, the v10 was a wonder to deal with
Apr 26, 2017 | 09:02 AM
It's a Innova 3130C.
I will try updating it's software.
If that don't help I will contact mfg.
Thanks
WhyFord
35
Jul 6, 2014 02:30 PM
Jnowaczyk
Modular V10 (6.8l)
Nov 6, 2013 01:02 PM
wldcat65
Oct 15, 2006 10:03 PM
fordbuilder
1997 - 2003 F150
Jun 28, 2005 10:40 AM
rgreen01
Jan 3, 2005 12:25 PM
