U-joint help, Numberdummy
Old Apr 25, 2017 | 07:53 PM
mOROTBREATH's Avatar
mOROTBREATH
I believe the U joint on my truck is going out, but I can't seem to find what I need. I think I ought to replace both, it is a 2 joint shaft
I have a 1956 F100 with the 223, 3 speed column MD trans, and Dana 60.
Rockauto has many but they're all out of stock and I have no clue which one I would need anyways.Thanks to anyone who can help.
Old Apr 25, 2017 | 09:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
See below, it's a very common Spicer 1310 joint.
NAPA: https://www.napaonline.com/en/search...plication=true
O'Reilly's: Spicer 5-153X - Universal Joint | O'Reilly Auto Parts
Autozone: International 1310 U-Joint - Best U-Joint Parts for International 1310
Old Apr 25, 2017 | 09:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1956 F100 would have a Dana 44, Dana 60 only installed in F250's.
C3AZ-4635-A (replaced B6TZ-4635-A) .. 1310 (cup size) Front/Rear U-Joint - 3 15/32" span / Obsolete ~ Available NOS & from auto parts stores.
Myriad 1956/79 FoMoCo vehicles.
EZ to find because: This U-joint was used at the front of the driveshaft on 1967/68 Mustang 289 & 1968/73 Mustang 302.
Old Apr 28, 2017 | 12:49 AM
mOROTBREATH
Sorry for the late reply, thank you both for answers.
Would it be the same joint for both(so I just order two of the same thing)?
What is the general consensus on greasable vx non greasable U joints?
Old Apr 29, 2017 | 04:37 PM
NumberDummy
Front & rear same u-joint for your truck, front only for the Mustang's I listed.
Old Apr 29, 2017 | 04:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The only downside to greasable joints is that you have to get the zerk in the right position, or you will not be able to get a grease gun on it.
Old Apr 29, 2017 | 11:25 PM
mOROTBREATH
Could you get me the part number for the transmission output shaft seal? It's a MD 3 speed on the VIN tag.
Thanks for the helps guys. Got the new spicers this evening and will do the work tomorrow. It is vibrating so bad I am not going to drive it, I really hope nothing else was screwed up, I just had to get it home.
Old Apr 30, 2017 | 12:44 AM
ALBUQ F-1's Avatar
ALBUQ F-1
C1TT-4813-C
Chicago Rawhide part number 507077
Old Apr 30, 2017 | 07:13 PM
mOROTBREATH
So its the same seal as used on a T98, thats nice to know.
https://www.ford-trucks.com/forums/6...placement.html
Old May 1, 2017 | 09:36 PM
mOROTBREATH
Hey Bill I was wrong, I don't have the Medium Duty trans, it is a "3-std". Therefor the seal was way off.
I used a dial caliper to roughly measure my output shaft and it is almost if not exactly 1.50". The new seal inside diameter is 2.12"
The original seal simply says NWB and a Ford logo, no numbers.
Sorry for the runaround, and thanks anyone who can further help.
Old May 2, 2017 | 04:00 PM
mOROTBREATH
Found what I needed at Oreily
T-86 output shaft Seal NATIONAL 470059
Ujoint DANA 5153X Spicer
Scotty's 52 F3
Oct 25, 2015 01:20 AM
cabloom300
Dec 27, 2011 02:40 PM
smbikes
May 9, 2009 10:47 AM
Davepig
Aug 17, 2006 09:16 PM
JerichoM1070
Dec 10, 2003 10:38 PM
