Got a set of u-joint from advance to replace in my 77 f100 shortbed but 2 of the cups were to small so i took them back and they culd not find any outhers that it called for so i went to napa and they had the same thing , the drive shaft takes the bigger cup while the yoke uses the smaller cups , has any one had these problem ? dose any one have a part # ?
Got a set of u-joint from advance to replace in my 77 f100 shortbed but 2 of the cups were to small so i took them back and they culd not find any others that it called for so i went to napa and they had the same thing , the drive shaft takes the bigger cup while the yoke uses the smaller cups , has any one had these problem? does any one have a part # ?
C5TZ4635F .. U-Joint / Dana/Spicer part number: 210392-X
2 cups are 1310 size, 2 are 1330 size.
This u-joint was first used in 1965 and is factory original to your truck.
but the one that came out of my truck used two clips and two half moon clips , the ones they crossed at autozone uses 4 clips and no moon clips .
how will thay work ?
