75 4x4 390 fe engine mounts
Old Apr 24, 2017 | 10:20 PM
elkarcher1716's Avatar
elkarcher1716
OK so I was trying to bolt the tranny to the cross member and it won't line up at all. The cross member is in correctly so the only thing I can think of is the motor mounts are backwards or on the wrong side. Am I thinking correctly or not? Anyone got some pics of there's by chance?
Thanks
Old Apr 24, 2017 | 10:29 PM
resonateur's Avatar
resonateur
The motor mounts are left and right. Furthermore the frame brackets have two set of holes that they can be installed into. Now, I'm assuming your 4x4 is the same set up as my 4x2...but that could be wrong, so I apologize if I'm unfamiliar. On my truck, with the 390 and C-6, the frame brackets go into the rear-most set of holes. The other holes will move the hole set-up forward about 3 inches. The motor mounts on the engine have a dot over the bolt. The dot goes up and the open side (three sides are surrounded by metal and one is not) faces forward.
Old Apr 24, 2017 | 10:55 PM
elkarcher1716
Thanks a million. The 4x4 are different but it still looks like I have mine 180 out. Go figure in screw something up after the fact. Well gotta lift the engine and flit them. Thanks agaim
Old Apr 24, 2017 | 11:21 PM
resonateur's Avatar
resonateur
Ummmmm....me too. Did the same thing, that's how I know!
Old May 16, 2017 | 04:36 PM
elkarcher1716
well I swapped the mounts around and I still am unable to get the tranny bolted down to the cross member. if I bolt the cross member in the tranny mount hits the cross member on top. I don't have the tranny mount 180 out. so I have no clue what the heck is going on. any ideas????
Thanks Tim
Old May 17, 2017 | 10:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There's only one rear rubber insulator, bolts to the rear engine support (aka cross member).
However, there are two different FE 4WD rear engine supports:
D4TZ-6A023-A .. 1973/76 F100/150 360 4WD C6 & M/T
D8TZ-6A023-B .. 1973/76 F250 360 4WD A/T & M/T; 1973/76 F350 360/390 T-19 4 M/T & C6; 1974/76 F250/350 360/390 Crew Cab 2WD M/T & C6; 1974/76 F100/250 Super Cab 2WD 360/390 C6.
Old May 17, 2017 | 05:13 PM
elkarcher1716
Yes I understand that there is only one rubber tranny mount but the cross member it sits on, I am unable to get bolted down. I can get one bolt on but the other side is off by Atleast and inch. I didn't have an issue taking the tranny out so I'm not sure if I have something else messed up with the engine mounts or what?
Old May 19, 2017 | 04:54 PM
hickory1991's Avatar
hickory1991
This is the only good pic I have right now. If you need better ones let me know. I will put it on my lift and take more recent, finished ones.
Old May 20, 2017 | 05:17 PM
elkarcher1716
Thanks hickory. I will let you know if I figure it out from here. That should work. Thanks agaim
Old May 21, 2017 | 03:57 PM
elkarcher1716
OK so is there a left and a right motor mount.? These are not marked and I'm fighting it pretty bad
Old May 21, 2017 | 04:30 PM
elkarcher1716
Took a little bit but I got it. Cross member might be a little tweeked
Old May 24, 2017 | 07:58 AM
hickory1991
Tim, hope these help. It's tight by the t/c, about an inch clearance from the 2 1/2 inch pipe. My muffler sits just behind the t/c.
Old May 25, 2017 | 01:04 AM
elkarcher1716
Wow that is tight. Yes that helps. Thanks. Mine is about the same. My issue is my fuel lines are running down the same side and with the exhaust right there I don't know how well that's going to work. Guess we will see
winginit
Jun 21, 2016 12:18 AM
keisha9
May 20, 2016 08:49 AM
willthesaint
Apr 4, 2016 07:42 PM
supertuff
16
Dec 8, 2014 07:57 PM
3Mike6
N. California Chapter
Apr 13, 2008 10:01 PM
