Red-Head Steering Box Question
Old Apr 24, 2017 | 12:49 PM
StreamOn's Avatar
StreamOn
I am getting ready to order a Red-Head steering box (36 spline) and need to know if I have to order the optional "PRE-TAPPED PORTS OPTION". I don't believe I need that option ($150 additional) but wanted to check here first.
Thanks!
Old Apr 24, 2017 | 12:56 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Thanks!
Are you doing a ram assist ? If not you don't need a tapped box
agsmv1's Avatar
agsmv1
Nope your OEM steering box does not have them.
Old Apr 24, 2017 | 12:58 PM
StreamOn's Avatar
StreamOn
No ram assist.
Thanks guys for the quick reply! Ordering now.
Old Apr 24, 2017 | 01:38 PM
IMASAP's Avatar
IMASAP
I would be a little jealous if you did a ram assist.
This may make you reconsider ??
Old Apr 24, 2017 | 01:49 PM
Misky6.0's Avatar
Misky6.0
Is that a code phrase for helping somebody driving a Dodge?
Old Apr 24, 2017 | 08:45 PM
Blakshukvw's Avatar
Blakshukvw
Every old ram assist I've seen on old mustang and corvettes leak. Pos
Old Apr 24, 2017 | 10:03 PM
pirate4x4_camo
FTE Remembers
Don't get an old one then. I've run several ram assist as well as full hydro steering setups and have never had a leak problem.
Howe and PSC make quality cylinders and with JIC fittings you should not have a single drop leak out.
Old Apr 24, 2017 | 10:10 PM
Blakshukvw's Avatar
Blakshukvw
Guess I don't see three need. Are these helpful when running taller wider heavier tires?
Old Apr 25, 2017 | 01:00 AM
pirate4x4_camo
FTE Remembers
Once you get to 37" tires and 5* + of caster the power steering on the SD/Ex is woefully underpowered, the ram takes the load off the steering box and increases the power. It essentially uses the steering box as orbital valve and a mechanical connection. Done correctly a ram steering even with large tires is better then factor with stock tires.
Old May 5, 2017 | 05:57 AM
StreamOn's Avatar
StreamOn
I had the RedHead installed yesterday and while the steering is much tighter, at low speeds it actually takes more effort to turn. Does that sound right?
Old May 5, 2017 | 08:46 AM
pirate4x4_camo
FTE Remembers
Sounds like a pump to me, however before you do anything I'd call the folks at redhead and discuss with them. I do not know if they rebuild the spool valve but they must test them. Give them a call
Old May 5, 2017 | 08:58 AM
StreamOn's Avatar
StreamOn
Thanks Pirate!
Old May 5, 2017 | 03:41 PM
LivingLarge's Avatar
LivingLarge
This happened to me, 2 weeks later it started leaking. I Replaced it with an OEM.
Good luck with it
Old May 5, 2017 | 04:08 PM
StreamOn's Avatar
StreamOn
Good luck with it
Thanks LL for the info! I will keep a close eye on it.
