1990 f150 oil leak BAD
I have a 90 f150 5.8 with a terrible oil leak ill lose a qt every 30 mins or so but only when driving or revving but not at idle it is only on the passenger side mainly off the cat cover a little off the transmission and oil pan bolts its all over underneath though that's just where it drips I just replaced the passenger side valve cover gasket I just noticed the drivers side valve cover was lose and clearly had oil puddle on it by the bolts I tightened it but still leaking the same amount I'm replacing the gasket later today. My question is can my oil pressure sending unit be the culprit it does go wacky at idle some times (if its not the valve cover) its on the opposite side but with pressure it could spray out and work its as around the engine I think? I'm pretty sure its not the oil pan gasket because it seems to be coming from above that and it doesn't leak all the time same with the rear main its dry inside the inspection cover and with how much I'm losing it should be covered if not puddles of oil in there. What could be causing this the drivers side valve cover? The oil pressure sending unit? Some other sensor on the back of the motor?
It runs great aside from needing plugs and wires I've never done a intake gasket on these motors but I've done plenty of intake gaskets on FE motors 352 360 390 and I know its a 4 piece gasket the two for the heads and one in front and one in the rear and if that's not seated right it will still run fine but leak oil out of the front/rear gaskets could this same thing happen on a 351? Or is it if one part of the gasket isn't good the whole thing is bad?
Buy a couple of cans of Gunk .....spray it down with it........take a garden hose and hose it off.............Then fire it up and rev it up......may need a helper to hold the throttle while you crawl around .....keeping your eyes open............That is the quickest way to find an oil leak......Don't just keep throwing parts at it hoping it will fix it........
