Power Steering Help...
Old Apr 24, 2017 | 04:29 AM
xgkrx's Avatar
xgkrx
Hello F.T.E.'s,
I would like to ask which Power Steering Gear Box IS THE BEST for My 1966 Ford F250 Pick Ups ???, and where is the best place to purchase this outright ???
I have one that is past repair and it needs to be replaced and I have seen a little info. that suggests that it would be best to use A Power Steering Gear Box from A 1976 Ford F250 Pick Up and I'd like to more more / as much as I can particularly as I'm here in Melbourne, Australia ( and approx. 4 Years ago I've was "taken for a ride from an E-bay seller !!! ).
Cheers and Best Regards
Graeme...
N.B. Both of My 1966 F250 Pick Ups are USA / Left Hand Drive Trucks.
Old Apr 24, 2017 | 05:53 AM
6t6merc's Avatar
6t6merc
Do you have a worn-out original manual gear, worn-out original Bendix power gear, or worn-out 69.5 - up swapped in power Saginaw type?
Eric
Old Apr 24, 2017 | 05:55 AM
xgkrx's Avatar
xgkrx
G' day Eric,
Thanks for Your reply.
I have a worn out Bendix Gear Box.
Cheers and Best Regards Graeme...
Old Apr 24, 2017 | 06:03 AM
6t6merc's Avatar
6t6merc
Good evening Graeme:
Not many of us up right now. I'm in Cambodia.
Best? My answer is a replacement of the original. This guy did a great job on my Bendix: Steering Solutions
I can't say he has one on the shelf though.
Eric
ps Weren't you looking for a crewcab?
Old Apr 24, 2017 | 06:06 AM
xgkrx's Avatar
xgkrx
Hello Eric,
again Thank You for Your reply.
You are correct,,, do You have one available ???
Old Apr 24, 2017 | 06:09 AM
6t6merc's Avatar
6t6merc
Nope, try Randy at the link above. Good luck.
Eric
Old Apr 24, 2017 | 06:16 AM
Inline66's Avatar
Inline66
Most people that are doing the conversion from manual steering say to go with the Ford/Saginaw box from later years. That's what I did on my 66 F100. But, this means either swapping out or shortening your steering column, and searching out the correct pitman arm and tie rods to make it all work together on your truck. There is a pitman arm that would allow you to keep your current tie rods with the later steering box, but it's only from 69.5-71 trucks. It was hard for me to find in the US, so finding it in Australia might be even harder. If I was in your situation, with a worn out Bendix box, I might consider getting it rebuilt or finding a replacement one. It would certainly save you a lot of work.
Here is a good article that explains the process: How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
Old Apr 24, 2017 | 06:20 AM
xgkrx's Avatar
xgkrx
Hello Inline66,
Thank You for Your reply and information,,, I certainly appreciate it.
xgkrx
Apr 27, 2017 10:33 PM
brenthottle
Jul 11, 2014 06:02 PM
upsfordman
Oct 19, 2005 12:42 PM
