Adjusting, fast and curb idle
My fast idle is way to high, my curb idle is to low. I think the kid who owned the truck before me kept adjusting the fast idle thinking there was only one screw for idle. Anyway where are these screw I use to adjust the fast idle, and the curb idle? Please describe where they are and what they look like.
Here is some pics of my carb
https://i.imgur.com/5P0n7hB.jpg
https://i.imgur.com/D0W8lIc.jpg
https://i.imgur.com/yzcZh1d.jpg
Thanks guys
Thanks guys
yes that picture. see the screw closest to the carb it's resting on the main carb body that's your curb idle, the other screw has nothing it's pushing against until the cam plate swings down when the choke is closed after you pump your pedal once. the bottom screw in your first picture is the idle air/fuel adjustment
im not going too give any tuning advice. I'm just now at 40 years old learning how to tune carburetor. My dad is a genius at tuning and I always relay on him. But he is getting older and it's time to learn he won't be around for ever. But he sets the timing every time he adjusted the carb. Saying that timing and carb adjustment play hand in hand. And he uses a vacuum gauge and a tachometer. And doesn't rest until the idle is perfect and the timing and air fuel mixture is perfect. So hopefully someone with more experience will chime in and explain
DAT2109
04-04-2012 09:12 AM
