change your u joints
Old 04-23-2017, 09:30 AM
cabloom300's Avatar
cabloom300
cabloom300 is offline
I had developed a vibration years ago especially while towing in first through second gear. I went over my u joints a couple years ago when i had the driveshaft out and everything was tight. I should have replaced them at that point. Ever since then the vibration had gotten worse until the rear joint became very apparent it was bad. Now with all three replaced in the rear it rides like a new truck. Even with the trailer in place (although i still have some axle wrap) it rides like a new truck. lesson learned.
Old 04-24-2017, 10:37 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
Yeah I will hopefully get off my butt and get mine done before anything bad happens. I have a slight stutter at start up. I know it is the joints...just haven't gotten to it yet.
Old 04-24-2017, 02:14 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Are you replacing the carrier bearing too?
Old 04-24-2017, 02:29 PM
BillyBob69's Avatar
BillyBob69
Who you asking? I plan on it. But need to research a little more to get the easiest way to do it.
Old 04-24-2017, 07:31 PM
cabloom300's Avatar
cabloom300
I actually did the carrier a couple years back when i developed a clunk. I debated on doing the joints then but they felt tight so i didnt do them when i should have. My rear one was shattered and the one middle one was so frozen you couldnt move it in the one direction. Honestly i cant believe the difference its made. Also it shifts like a new truck (its a 6 speed) very smooth while shifting and no clunking at all. Enough rambling, just get off your butt and do them lol
Old 04-24-2017, 08:46 PM
stevedrums's Avatar
stevedrums
stevedrums is offline
don't forget loc-tite on the strap retaining bolts!
Old 04-25-2017, 07:21 AM
cabloom300's Avatar
cabloom300
Yep I did. I learned that lesson before to lol
Old 04-25-2017, 08:48 AM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Which ones?
Old 04-25-2017, 06:01 PM
Bently_Coop
Anyone taking on the project. I had the local driveshaft shop replace U-Joints and Carrier at the same time. Should of had it balanced and painted but oh well. I didn't do because of vibration's, I had the first gear clunk and didn't want any more issues.
Old 04-25-2017, 08:34 PM
cabloom300's Avatar
cabloom300
As far as the bolts i believe hes is talking about the one on the rear yoke/differential. Those are the ones i did and also had come loose.
Old 04-26-2017, 08:09 AM
brandon_oma#692
Thanks I will double check mine.
Old 04-26-2017, 10:21 AM
BillyBob69's Avatar
BillyBob69
...... Enough rambling, just get off your butt and do them lol
Yeah yeah yeah....sheesh
Old 04-26-2017, 11:21 PM
268Fords's Avatar
268Fords
268Fords is offline
I just replaced mine and my rear didn't have bolts. Shaft and differential yoke were both pressed in. Pain in the *** that one was.
Old 04-26-2017, 11:22 PM
268Fords's Avatar
268Fords
268Fords is offline
I just replaced mine and my rear didn't have bolts. Shaft and differential yoke were both pressed in. Pain in the *** that one was. Only my middle joint has bolts.
65f100_352
1978 - 1996 Big Bronco
03-13-2018 02:47 PM
Bigpipes 35
1999 to 2016 Super Duty
23
08-24-2015 02:12 PM
GreatWhite99
05-28-2010 08:08 AM
99sbm
41
12-29-2008 11:21 PM
Quick Reply: change your u joints
