Sponsored by: Real Truck
New Ujoints equals vibration
Old Aug 22, 2015 | 04:33 PM
Bigpipes 35's Avatar
Bigpipes 35
Ok so I replaced the rear axle U-joints and hanger bearing and now have a bad vibration. I marked every joint to ensure correct reinstall . Today I put the old hanger bearing back on to see if that changed anything and it didn't. Can someone take a pic of the rear shaft so I can see if something is different. I have a crew cab short box. I don't want to have the driveshaft rebalanced but I might have to. On a side note before I replaced everything the truck was smooth as silk...
Old Aug 22, 2015 | 05:01 PM
MisterCMK's Avatar
MisterCMK
What pictures do you want?
Old Aug 22, 2015 | 05:49 PM
Bigpipes 35
Where the slip joint is would be great. How are things with you going . Did you get out with the guys camping a lot this year??
Old Aug 22, 2015 | 06:04 PM
bobv60's Avatar
bobv60
the front and rear u joints should be in phase. pictures are better than words
https://www.google.com/search?q=univ...0OVHQBuvW7s%3D
Old Aug 22, 2015 | 06:06 PM
bobv60's Avatar
bobv60
this might be a better pic
Old Aug 22, 2015 | 06:36 PM
hav24wheel's Avatar
hav24wheel
Did you put greaseable joints in? If so, you will need to rebalance it. Did you use spicers? If not, rebalance it.
Old Aug 22, 2015 | 06:38 PM
Bigpipes 35
I did use greaseable and not spicer but Napa premiums
MisterCMK's Avatar
MisterCMK
We are out camping near Alexandria now lol
I'll see if I can grab a quick picture for you
Old Aug 22, 2015 | 06:43 PM
hav24wheel's Avatar
hav24wheel
Take it in, there's the problem right there. I swapped from non to greaseable, all in spicer brand and had to rebalance it.
Old Aug 22, 2015 | 06:47 PM
Bigpipes 35
That's what I didn't want to hear, how much did it cost to have it balanced??
Old Aug 22, 2015 | 07:03 PM
hav24wheel's Avatar
hav24wheel
Every location is different. Here was $110 for a single shaft. It's more for a hanger style
Old Aug 22, 2015 | 07:38 PM
MisterCMK's Avatar
MisterCMK
Here ya go Chris
Old Aug 22, 2015 | 08:03 PM
Bigpipes 35
Here ya go Chris
Awesome thanks Bud, We go up to Alec in a couple weeks for the 4H state shoot. Have fun and I hope the weather doesn't get to crazy up there..
Old Aug 22, 2015 | 08:05 PM
Bigpipes 35
Its crazy to think just because you change U-joints that you would have to rebalance...
Old Aug 22, 2015 | 08:41 PM
hav24wheel's Avatar
hav24wheel
You probably could have got away without rebalance if you would have put the spicer life series back in it.. When you put greaseable joints in vs non, you throw the balance off due to the zurks. You wouldn't think that little bit would make a difference but it does.
