Power Steering Whine
Old Apr 22, 2017 | 11:23 AM
SmackDaddy's Avatar
SmackDaddy
I have done a lot of research on this before asking. After my recent cooling system upgrade and power steering pump/HP hose replacement I am still hearing and feeling the power steering whine. I flushed the fluid and used Mercon V ATF fluid. I jacked the front end up with tires off the ground and cycled the steering lock to lock 100 times or more now and the whine does not stop. Do I need to put a vacuum on the system and try to purge it that way? There was no whine before but I just replaced the pump while I had room with everything out of the way and replaced the high pressure line because the fitting was leaking at the pump. This is very irritating because I thought replacing the pump would be beneficial.
Old Apr 22, 2017 | 01:06 PM
TooManyToys.'s Avatar
TooManyToys.
Would that happen to be a Motorcraft replacement?
If so my second replacement continued to while, and a few other members here had the same issue with Motorcraft replacements.
Old Apr 22, 2017 | 01:13 PM
SmackDaddy's Avatar
SmackDaddy
MasterPro Power Steering 712-0131 - Power Steering Pump | O'Reilly Auto Parts
cory5517
Dec 29, 2024 10:51 AM
___
Aerostar
16
Nov 17, 2023 10:54 AM
Kevin Bradshaw
May 23, 2019 08:11 AM
billg302
Apr 15, 2009 11:07 PM
FLJ
Sep 9, 2006 04:43 PM
