my 4inch skyjacker kit
Old Apr 22, 2017 | 05:07 AM
vemax's Avatar
vemax
i just purchased a 4inch skyjacker lift kit for $180
needs a good clean and paint then install.
didn't want to go too high , 4inch is perfect.
Old Apr 22, 2017 | 08:46 AM
CountryBumkin's Avatar
CountryBumkin
Nice buy!
The shocks may be worn out by now - but you can deal with that later if needed.
A few small parts missing but easy to get.
Old Apr 22, 2017 | 08:56 AM
vemax's Avatar
vemax
hi CountryBumkin
can you tell me what parts are missing, wasnt sure if it was complete.
as for the shocks they seem ok still.
Old Apr 22, 2017 | 09:23 AM
CountryBumkin
Upper shock bushings/insulators (fit over stud end of shock. Two per shock), eight grade 8 washers to go under u-bolt nuts, if you have front sway bar there are drop down brackets for the sway bar mounts (like 2" x 4" hollow rectangular blocks), you will need/want a "drop pitman arm" too. I think you can reuse the bottom spring seats/retainers unless new springs are different diameter
You may be able to use the stock brake lines for front (by bending frame bracket down). You need to check rear flexible (frame to axle) brake line. Will probably need to get a longer one.
Old Apr 22, 2017 | 12:52 PM
Franklin2's Avatar
Franklin2
With a 4 inch lift, the dropped pitman arm is not optional if you want good steering.
Old Apr 22, 2017 | 04:40 PM
4x484150's Avatar
4x484150
Good deal! Im looking to get a 4 inch as well. Perfect height IMHO.
03_PSD
Jan 29, 2010 04:02 PM
Clint40
May 5, 2005 04:29 PM
mattd17
Feb 2, 2005 11:58 PM
Lee Lichterman
Dec 7, 2004 07:05 PM
Yeti
May 13, 2002 05:35 PM
