Sponsored by: Real Truck
Hey Chadrock
Old May 13, 2002 | 12:21 PM
Yeti's Avatar
Yeti
Hey Chadrock
Question about your front spring hangers.
What is included with the kit? The 2 front hangers and rear hangers?
Also ,would I need a different track bar bracket If I added these?
Thanks
Old May 13, 2002 | 12:36 PM
chadrock's Avatar
chadrock
Hey Chadrock
As far as mine, honestly, I'm not sure. I bought all the parts for my lift at the same time form the shop that lifted my truck. I never saw all the parts. They called me up on day and said, "Your parts are here." I dropped the truck off and picked it up a day later.
In a hanger kit though, you don't get rear hangers; only front ones to level the truck out (its basically a leveling kit for stock trucks). If you order a kit, I think you can get it with the hanger brakets and different shocks (to compensate fot the added hight of the hangers) I think with mine, though, they just ordered the hanger brakets because I ordered Rancho RS9000 shocks so there was no need for me to get the Fabtech shocks. I'm pretty sure they used the stock track bar on mine so they probably could do the same on yours. Hope this helps.
Old May 13, 2002 | 12:52 PM
Yeti's Avatar
Yeti
Hey Chadrock
Thanks Chadrock,
I just got of the phone with them, if I went with the hangers, I would need 6 new shocks, adjustable track bar and extreme drop pitman arm.
I was hoping it would be cheaper to go with that setup but all in all looks like it may better just to step up from my 6" to a complete 8" kit.
Then I'm thinking , seems like a lot of cash to spit out for an additional 2" from where I'm at now.
I may just throw a 3" body lift in there, just want to run 39" but I really can't go higher with my frame, due to my snow plow.
You guys on the West coast got it made!!! X(
Old May 13, 2002 | 01:22 PM
abendx's Avatar
abendx
Hey Chadrock
at 9" (6" suspension and 3" body) you will not fit 39" tires.
i know a guy at 11" running 39.5" TSL's and he says he gets a very slight fender rub.
chad.... how do the 39.5's fit under your 11"?
Old May 13, 2002 | 02:09 PM
chadrock's Avatar
chadrock
Hey Chadrock
I had to do a slight fender trim, but my tires are on 14" wide wheels.
Old May 13, 2002 | 03:08 PM
chadrock's Avatar
chadrock
Hey Chadrock
Old May 13, 2002 | 05:35 PM
HIROLLN's Avatar
HIROLLN
Hey Chadrock
I had to do a little front bumper moving as well on my little 6.5 inch lift with 36x14 swampers But I went with 12inch rims! Which is why we had to shim the bumper!
