Replace Duraspark with MSD-6AL
Old Apr 21, 2017 | 11:56 AM
BossFan's Avatar
BossFan
My 1978 F250 has a 1984 351W and the Duraspark electronic ignition and stock distributor. I have a MSD 6AL that is just sitting on the shelf. Is this a straightforward swap? Do I need a different coil?
Thanks!
Old Apr 21, 2017 | 05:08 PM
Franklin2's Avatar
Franklin2
There are several ways to do it. You can keep everything you have, and let the original coil wire trigger the MSD box. You will keep your dist, duraspark II box too. Instead of the duraspark box triggering the coil, it will trigger the msd box. You can reuse your stock coil.
The other way is to buy one of their harnesses, and let the Ford duraspark distributor trigger the msd box directly without the ford duraspark II module.
The another way is to buy a MSD distributor for your Ford application, and install it and let it trigger the msd box.
Check their website, they have very good instructions there you can download.
Blue and White
Nov 6, 2011 02:17 PM
crescentwrencher
May 14, 2008 08:38 PM
cjbronco
16
Oct 12, 2005 03:13 PM
little_mule
Electrical Systems/Wiring
Sep 12, 2005 01:14 PM
dhag911
Aug 7, 2004 12:57 PM
