'85 F350 351 non-FI tank and sender needed
#76
#78
EOTZ-9034-N .. Fuel Filler Tube-Use with Unleaded Fuel & Mid-Ship or Aft Axle Fuel Tank / Obsolete ~ 3 available NOS
1980/89 F250/350 Regular & Super Cab Cab & Chassis / 1980/89 F350 Regular Cab Cab & Chassis with 133" wheelbase.
E1TZ-9047-J .. Upper Fuel Filler Hose-Use with Mid-Ship or Aft Axle Fuel Tank / Marked: E1TA-JA / Obsolete ~ 16 available NOS
1981/89 F250/350 Regular & Super Cab Cab & Chassis.
E1TZ-9047-T .. Mid-Ship Fuel Tank Lower Fuel Filler Hose / Marked: E0TA-9A116-EA or E1TA-9A116-DA / Obsolete ~ 0 available NOS
1980/89 F250/350 Regular & Super Cab Cab & Chassis.
#79
#82
Yes, the vent tube, the one that goes down inside the fill neck on the tank and runs inside the fill hose towards the gas cap.
Any ideas about what to do about another fill hose? I thought that I could make one from exhaust tubing and use straight fill hose sections as couplers, but I really don't want to.
#83
#84
Update:
The sender I bought appears to be identical to the old one and the float arm sweep was from 10 to 70 ohms. It fit nicely into the Spectra tank after I bent a couple of the tabs for the lock ring just a bit. The new tank is in the truck.
I was a little concerned about how tightly the fittings for the fuel lines felt, but they are installed correctly, I just figured they would be a little more tight on the output pipes for the sender.
I think I'm going to reuse the old fill hose since they are NLA. This one isn't new, but it's better than nothing.
Next step is to remove the power steering pump so I can install new rubber hoses for the transition from the hard fuel lines to rubber at the fuel pump.
#85
First off, let me say thanks to everyone who has taken the time to help me with this project. I wouldn't have been able to get it going again without the help.
The fellow who owns the truck was my father's best friend growing up. They met when they were 7 years old. I lost my father back in '97, so it's been nice getting re-acquainted with someone who grew up with him. Hearing all of the stories about my father and his family from when he was a youngster has been a real hoot.
I started the truck today with the new tank and sender and it runs! It started right up.
The only other item that seems to need some attention is the power steering pump. It appears to have leaked quite a lot of fluid all over the rubber hoses at the fuel pump and the lower radiator hose is covered as well. I'm going to replace these items with new rubber, but what's the best option for the pump? It's got about 1/4" of play on the shaft.
Thanks.
Thanks.
#86
Thanks.
Thanks.
Also nice you have someone who knew dad and can fill in the blanks.
For that pump and play you have 2 options.
Junk yard for a user one that may go bad in a short time or not?
Get a rebuilt one from parts store. If it goes bad hope it is still under warranty and turn it back in for another.
Dave - - -
#87
#88
Thanks.
Thanks.
The thread may not be the one I was hoping for as the OP ran into some frame issues and the discussion centered around that. Anyway, the Redhead steering boxes come highly recommended by several forum members.
Last edited by 1986F150six; 05-11-2017 at 11:02 AM. Reason: May be incorrect thread. Sorry!
drewthestu
06-09-2014 04:28 PM
lavatan
67
05-01-2012 11:22 AM
