I'm trying to locate a regular access panel so I can get rid of my tailgate pole and the plastic cover that goes with it. Prices are crazy ($300+) and availability seems to be nil. I did this to my '11 SD and I think I paid $60 from Tasca. Any suggestions would be greatly appreciated.
It attaches with 6-8 existing screws/holes. No drilling required. Instructions had you using exsisting screws but with the thickness of the cover, my screws only caught by a thread or so, so I bought little longer screws.
If you want something to cover the void, just get a piece of thin aluminum plate, trim to fit, then cover with protective cover.
Sorry, yes I have it installed. I added some drywall screws (the ones made for metal studs) around the lower perimeter to keep it from lifting.I have the pull-out step so the plastic cover wasn't a perfect fit, but with a little rasping and some different mounting screws I have a good fit. Its strong enough to leave the access cover out, but in full sun/heat it starts to warp and heave due to the expansion of the plastic. It's fine for now but I'm keeping my eye out for a metal panel (at a real-world price) then I'll shoot the tailgate in Rhino to match the rest of the bed. Thanks for steering me onto that. It's a good solution until I find the metal panel, If I ever do.
