Man Verses Heater Core
Old Apr 18, 2017 | 03:21 PM
Bryanblaylock's Avatar
Bryanblaylock
Hello all,
Recently my heater core popped and sprayed all over the cab, I filled the radiator and double checked the problem.
Anyway, I like my heater and I want to replace the heater core so I can cruise around at night again...
I have a 1977 F150 with 351M 4 speed and air conditioning, I think I have AC (It doesn't work, but I have a pump and the vents for it)
I have removed the 3 bolts from the engine compartment, unplugged the wires, disconnected the cables, and wiggled that thing until I was ready passout (using prybars and all leverage I could get)
any tips? It doesn't wanna come out, Here are some photos....
Please help...
-Bryan
Old Apr 18, 2017 | 04:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have a 1977 F150 with 351M 4 speed and dealer installed Economy A/C (It doesn't work, but I have a pump and the vents for it).
1973/79 F100/350 & 1978/79 Bronco heater core used with dealer installed Economy A/C is the same as with heater only.
Dealer installed Economy A/C has two A/C switches that fit into a panel that also contains two registers. This panel fits into the dash to the left of the glove box (as pictured above).
Old Apr 18, 2017 | 06:34 PM
tabascom16's Avatar
tabascom16
So I know I had troubles getting mine out before. So I decided to go look at it. It looks like there may be a screw in the bottom left corner towards the driver side. Also, there is several screws holding the "human operated vent" to the main heater box. I apparently had to get all those screws out and when I put it back in I left the top 2 out because there was no easy way to get to them. I got an AC system like that out of a parts truck one time and I think it was a complete separate "black box" that went in the hole above the normal heater box and behind the glove compartment.
Old Apr 18, 2017 | 07:30 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
All I got on hand. 1979 F100 Air Conditioning
NORTH COUNTRY SPECIALTIES ®
No big box in the engine compartment, so yes dealership installed a/c.
Old Apr 18, 2017 | 07:49 PM
maytea's Avatar
maytea
Re
From the pic it looks like my heater only box
As per other post
Take out the fresh air vent.
Reminds ve heater hose and 3 nuts in engine bay.
Remove the backside dash bolt next to pass side door. Below the far right vent.
Have someone pull dash out about 1 inch and heater will slide out through the larger opening available
Hope this helps
https://www.ford-trucks.com/forums/1...placement.html
Old Apr 18, 2017 | 10:38 PM
fuzzybob's Avatar
fuzzybob
Maytea is correct. In addition to the dash bolt by the pass. door there is one by the ash tray that I had to remove and if needed one over by the driver's door. Keep after it and good luck!!
bootless1075
Oct 21, 2018 09:07 PM
jaleus
Mar 10, 2018 01:52 PM
CB3
Oct 1, 2013 09:48 AM
Black Ford XLT
Apr 5, 2008 07:19 PM
