F-250 suspension
Old Dec 2, 2001 | 12:09 PM
charger's Avatar
charger
F-250 suspension
Howdy. Can any of you tell me if the front spindles from an early '90's F-250 will bolt into the I beams of a plain F-150? Are there any big differences in an F-250 front suspension that would disable it from bolting into an F-150 frame? Thanks,:*
Old Dec 2, 2001 | 06:58 PM
jakegypsum's Avatar
jakegypsum
F-250 suspension
I don't believe that the spindles are enterchangable but the entire axel swap should work. Keep in mind that if you change the front, you should change the back as well. Good luck.
Old Dec 2, 2001 | 07:02 PM
jakegypsum's Avatar
jakegypsum
F-250 suspension
blick
16
Jul 2, 2014 12:00 PM
Moonpie6899
Nov 23, 2012 11:51 PM
Moonpie6899
Nov 19, 2012 06:00 PM
mavman4
Nov 10, 2003 09:24 PM
