Odd cooling problem
Old Apr 19, 2017 | 09:46 AM
yardbird's Avatar
yardbird
Let the truck sit several hours then crack the oil plug until either oil or water comes out. As much water as you are loosing, it could be going into the pan too. Might be head gasket or intake gasket if there is water in the oil.
Either way, you want to make sure there is no water in the oil.
Old Apr 19, 2017 | 10:41 AM
cscott952's Avatar
cscott952
Good idea. Thank you.
Old Apr 21, 2017 | 08:47 PM
basic150's Avatar
basic150
Originally Posted by mrollings53
Coolant runs unobstructed through the heater core. Air baffles are what determine whether the heater is "on" or not.
oh thanks for the info. Now I know.
Old Apr 25, 2017 | 01:22 PM
cscott952's Avatar
cscott952
This turned out to be air in the system after all.
1. Drained about .5 quart of oil after the truck sat overnight. No evidence of anything but oil in the pan.
2. Burped truck parked up hill.
3. Topped off the cooling system on level ground once engine cooled off.
4. Took the truck for a couple long drives. Radiator level coolant level remained full, and the expansion tank rose and fell as expected.
Thanks for the help everyone.
Old Apr 25, 2017 | 09:26 PM
Benztechnc's Avatar
Benztechnc
Did you pressurize the coolant system? If so how much pressure, and how long did it hold?
Old Apr 26, 2017 | 06:48 AM
cscott952's Avatar
cscott952
No, I didn't pressurize outside of just going for a couple long drives. I did test the cap which held its 13 psi rating. The expansion tank rose about .5 - 1" after each drive, but returned to its original cold level when the engine cooled down.
collkid
13
Nov 23, 2018 06:13 PM
wresleu
Aerostar
Apr 29, 2006 11:57 AM
68ragtop
3.8 & 4.2L V6
Feb 25, 2006 02:25 PM
rangersvt04
1983 - 2012 Ranger & B-Series
20
Mar 30, 2004 07:17 PM
blackpowder
Apr 3, 2003 06:49 PM
