Wheel and tire offset
Old Apr 17, 2017 | 07:22 AM
Justin Weiss's Avatar
Justin Weiss
I searched and did not come up with any clear answers. I have converted my f1 to IFS and an upgraded rear so everything is 5x4.5 and is still the factory track width, The wheels I am looking at are 18x8 in the front and 20x10 in the rear with a 4.5 backspacing and a 0.00m offset. I am not worried about the overall size of the wheels just wondering if the offset and backspacing is correct. Any help would be great.
Thank you
Old Apr 17, 2017 | 08:23 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Justin, do you plan to tub the box or expand the width of the rear fenders? Offset is measured from the centerline of the wheel and backspace is measured from the inboard edge of the wheel. So, to get 4.5" backspace with 0 offset, the wheel would be 9" wide.
Old Apr 17, 2017 | 09:06 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
I try to stay out of darkside questions like this, but believe this chart might be helpful. An 8" wide rim is measured inside across the inner rim base. So "0" offset means 4" each side of the center disc (edit - more correctly, the wheel mounting surface). The backspace concept adds the width of the rear rim lip to the calculation. Rim lips generally add 1/2" to the backspace figure. So to me this set of variables does yield 4.5" of backspace on an 8" rim.
It might also be helpful to add that the stock F-1 wheels, 16" x 4.5", have .62" of positive offset. And as you go forward with this also be sure to factor the "section width" of the various tires you consider. Tire rub is as much an issue as wheel spacing. Stu
Old Apr 17, 2017 | 09:07 PM
old_dan's Avatar
old_dan
Hello guys....it's been a while since i've posted anything at all.
This question popped up from time to time. I found this website was helpful for doing all of the measurements: https://www.rsracing.com/TechWheel.aspx
Dan
Tushy
Apr 13, 2016 12:09 PM
Jeff55F100
Nov 7, 2011 04:56 PM
Nebraska
Nov 18, 2005 11:48 AM
wolffee
Feb 8, 2005 12:57 PM
svooom
Oct 17, 2004 04:12 PM
