Valley wiring harness?
Old Apr 16, 2017 | 09:37 PM
jnk317's Avatar
jnk317
Since a few of the wire pigtails in the valley have seen better days, I was wondering if anyone knows if someone sells the valley wiring harness and/or the part number for it (from big square connector under air intake/on top of driver side bank to include all things in the valley).
Old Apr 17, 2017 | 11:49 PM
Mike321's Avatar
Mike321
I would also be interested in this.
Old Apr 18, 2017 | 04:49 AM
Walleye Hunter's Avatar
Walleye Hunter
I believe it is called the engine wiring harness and it should be available from Ford with your VIN. They can also be found used on fleabay. New is north of $500.
Old Apr 19, 2017 | 09:06 AM
helifixer's Avatar
helifixer
I think I actually got the last one I installed from Walmart online. motorcraft part, delivered in 2 days. also check orillyes they are now a motorcraft vendor
Old Apr 19, 2017 | 12:58 PM
brian42's Avatar
brian42
Veteran: Navy
Ford no longer makes a lot of parts for our trucks. If you can't find new (or it's out of your budget) you might want to try some recycling yards in your area (aka pick-n-pull or junkyard) or online (LKQ, Car-Parts.com, etc.).
I'm not a big fan of third party stuff for our trucks so if I can't find OEM new then I try to find used OEM in good condition.
Short story long: I had a tire blow out and the shop told me that some of the wiring that got destroyed was no longer available from Ford so they would have to get an aftermarket replacement. I was able to find what I needed at a local salvage yard and splice it in to keep everything OEM. Cost me an afternoon and $10.
Old Apr 22, 2017 | 02:26 PM
jnk317's Avatar
jnk317
I couldn't find it on Walmart's site... any chance you have the part number handy?
Old Apr 25, 2017 | 10:09 PM
jnk317's Avatar
jnk317
I wish I could have found this on one of those sites. Found this site though...Part number -
F81Z-12B637-FA - FDZWH00015
https://www.1aauto.com/2002-03-ford-...a/i/fdzwh00015
earlbenz
2009 - 2014 F150
Feb 10, 2019 10:48 AM
louisianman
18
May 31, 2007 01:14 PM
tn terry t
Bronco II
May 17, 2007 07:59 AM
osborn_1
13
May 13, 2007 10:45 PM
78f150custom
Jan 31, 2004 02:31 AM
