Replace Side Marker/Clearance Lights with LED?
These units from Amazon are the correct overall size and have the correct center-to-center screw hole dimensions. But there is no lumen output specification to compare them against other products.
http://a.co/a7zlUWW
If you've replaced your lights and like what you got could you let me know which ones you bought?
Here is what I went with for the amber:
The reds I bought are no longer available, so here is a listing that I'd go with if I had to buy another batch of red's:
Reasoning to stick with the original fixture was that I would not have to worry about finding a one-off LED fixture in case something whacked the trailer. Also, replacement lens are still commonly available for my fixtures.
While not part of the original question, I did the same thing with the tail lights and just switched the bulbs over to LED. My go-to source for that type of application is V-leds. V-leds is a bit more expensive and worth it from a quality / durability and customer service perspective.
Finding new fixtures has been a bit of work. I wanted new sealed units that had 3" centers for the screws, with the wires coming out in the center of the light. It looks like very few fixtures come with the gasket any more. I'll be busy with the caulk.
Have had the joy of fixing a PO's work from a LED fixture conversion on a former trailer. Make sure the weep holes are on the *bottom* side of the mount and *not* covered by caulk. After I fixed those two issues, the moldy smell and leak magically disappeared ;-)
Level of effort for the fixture replacement (based on my repair experience) is about the same as the side-light replacement that you did a few months ago; only difference is doing it on a ladder
What kind of fixtures are currently on the RV? If they are Bargman's, the fixtures are relatively inexpensive where the bonus is that you may re-use the LED bulbs.
