Door panel removal
Old Apr 16, 2017 | 07:42 AM
Shortbox4x4's Avatar
Shortbox4x4
Door panel removal
I did a search and checked the technical links and didn't find anything.
I can get a set of door panels for free......I take them off. No sweat. Of course my panels most of the tabs are broken. A lot of ones I see for sale have broken ones also......so before I attempt this are there any tricks or special tools needed to take the door panels off of a '77?
Thanks, shortbox4x4
Old Apr 16, 2017 | 08:13 AM
good to doo's Avatar
good to doo
Panel removal tool, it,s just a thin flat piece of metal with a slit in it. Slip it in behind the plastic panel right where the clip is. No more broken panels.
Old Apr 16, 2017 | 08:45 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is a place to get one. Lisle 35400 - Door Upholstery Remover | O'Reilly Auto Parts
Most other chain parts stores carry them too. You can make one from a big ol flat tip. Torch heat and bend a 45 in it, grind a V in the end.
Or once you have the window crank, finger pull cup and inner door latch handle removed. Start on the bottom either corner, slip a flat tip in from the bottom in line with the tab. Put your hands/fingers on BOTH sides of the tab (behind the panel, unless you have monster gorilla size hands, lol) and your thumbs on the outside and carefully pull with steady easy pressure. Just do not go yanking on it, its a controlled pull, cause one it comes out, you need to STOP pulling.
If the door panel has the older metal tabs...or real new push pins...just go buy the tool.
You can also use a hack saw blade (with tape as a handle) and slip it behind the panel and just cut the push pins too.
If you have broken tabs you can graft replacement on it.
grinnergetter
24
Aug 22, 2014 05:24 AM
pizalm
Jul 10, 2004 07:35 PM
rbrad9753
Paint & Bodywork
Feb 9, 2002 06:13 PM
bail5067
May 13, 2001 09:38 PM
Dewy
Oct 31, 1999 05:30 PM
