rear differential flush and refill question
Old Apr 15, 2017 | 07:45 PM
scottm1's Avatar
scottm1
I did a rear differential flush and refill on my 02 F-250 today. I put back in 75-140 full synthetic just like I was supposed to. However, when it came to putting the friction modifier in, I went to the oem clutch pack kit I have that a buddy of mine had for his truck that he gave to me since he sold his truck before he put it in. Inside that box was 3 bottles of the XL-3 friction modifier. So I thought, well 3 bottles is what it takes or they wouldn't have put 3 bottles in the kit, so I put in all 3 of them(12 ounces). Then I got to thinking, that seems like too much. So then I go looking it up on Prodemand.com(subscription website for mechanics), and it says it takes 8 ounces(2 bottles). My question is to you mechanics out there.....will having 4 ounces too much hurt anything? Do I need to suck a quart out and put back in another quart of just gear lube to dilute it down 33% from what it is now. Any opinions?
Old Apr 16, 2017 | 12:20 AM
SGnAZ's Avatar
SGnAZ
What brand gear oil did you use?
I used Mobil1 last year and it already has the additive in it,no need for anything else.
Trouble free for many miles.
Old Apr 16, 2017 | 12:53 AM
BBslider001's Avatar
BBslider001
This is what I did as well just last week. I was going to ask the same thing.
Old Apr 16, 2017 | 04:00 PM
helifixer's Avatar
helifixer
the friction modifier reduces the friction on the limited slip clutches. too much modifier make the clutches too slippery and you end up with the equivalent of on open diff.
after a fluid change I don't add any modifier, most GL5 gear lube has enough in it.
Change fluid drive to warm up oil, make a slow turn to the right and left, if there is a popping sound or chatter when turning add 2 oz of modifier drive enough to mix it in to the gear lube and do slow turns again if no popping of chatter you are done. keep adding 2 oz and repeat above until turns are smooth.
Old Apr 16, 2017 | 04:29 PM
mueckster's Avatar
mueckster
While my truck didn't come with a LSD and I installed a True Trac (no friction modifier necessary), I agree with your recommended procedure. You hit upon key points that the OP needs to know.
Old Apr 19, 2017 | 10:21 AM
Fat Diesel's Avatar
Fat Diesel
IMO you now have an open diff. I'd drain it and put just new oil in. You likely have plenty of F/M on the clutch plates now. If you get chatter, add a little F/M until it goes away.
twall_SD250
Jun 16, 2016 08:49 PM
coreyallan01
Jan 11, 2014 11:55 PM
Texas Bob
Jun 16, 2012 02:52 PM
brian931
1983 - 2012 Ranger & B-Series
Apr 8, 2009 07:16 AM
95Z71
26
May 18, 2008 11:54 PM
