Aux tank overflowing!
Old Apr 15, 2017 | 03:27 PM
xxkenny90xx's Avatar
xxkenny90xx
1978 f-250 supercab 400 motor 4bbl carb
Hey guys so I almost never use my aux tank because the sending unit is bad and it should be close to empty (i keep about 3 gallons in it for emergencies). I drove my truck 2 weeks ago and filled up the main tank, then drive it again 2 days ago. It was 3/4 full when I got home. Yesterday morning I got a call from a neighbor that the aux tanks cap is leaking. When I got home there was no leak but some gas on the ground. I opened the cap and the tank was full to the top! I suspected the neighbor kids may have put the water hose in there until this morning when I went out there and it was dripping again. I removed the cap and it just keeps pushing gas out. So I put the cap back on to slow the leak. How could the tank be all of the sudden full and how could it be pushing fuel out of the cap? I wondered if gas was somehow making its way there from the main tank but it's still showing 3/4 full. Also It did rain yesterday but not today. Anybody have any ideas? I'm lost on this one
Old Apr 15, 2017 | 03:46 PM
march's Avatar
march
I would also suspect that your tank selector valve is stuck half way between the two tanks allowing fuel to move from the aft tank to the saddle tank. I've had this happen on my supercab. It is strange however that you still show 3/4 tank on the rear. Maybe the saddle tank has been filling for a while and just now overflowed.
Old Apr 15, 2017 | 03:51 PM
xxkenny90xx
Hm I see what your saying but would that cause fuel to keep pumping out of the cap continuously while the truck hasn't moved in 2 days?
Old Apr 15, 2017 | 03:55 PM
xxkenny90xx
At this point I'm nervous to use the aux tank at all in case it has been somehow topped off with rain. But it's sunny now and still dripping away
Old Apr 15, 2017 | 04:19 PM
march's Avatar
march
Is it warm outside? Gas will expand quite a bit. Could be that during the day it warms up enough to push it past the cap.
I don't know how you would check for water, maybe someone else on here will have a bright idea.
Old Apr 15, 2017 | 04:24 PM
xxkenny90xx
It's hot outside as far as us Washington people are concerned (51°). I was thinking I'd try siphoning some gas and seeing how it settles (wouldn't gas and water separate)? I had to leave for the day so I parked it on a slight incline with that tank at the top, who knows maybe that'll help a little
Old Apr 15, 2017 | 04:44 PM
lasermike's Avatar
lasermike
Water any gas don't mix. I'm old enough to remember glass bowls in the fuel line to catch water before it hits the carb. It settles to the bottom, that way you could open the petcock n the bowl and drain it out. Small aircraft had then in the wing tanks and were checked preflight.
Unfortunately, you won't be able to check for water from the top side (except maybe with a test strip) so you'll have to draw some from the pickup or the drain plug. I also think it could be the tank selector and that it's still leaking out of the aux because the both the main tank and aux tank contents are expanding. Try opening both caps. If it's the selector, I'd think the level in the aux would go down.
I'm stuck in a windowless building in Kent just south of IKEA. I'll have to take your would that it's nice outside ��
Michael
Old Apr 15, 2017 | 04:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford did not install saddle tanks in any truck. Saddle tanks have one tank on the left side, one tank on the right side.
The OP's truck probably has a mid-ship tank and an aft axle tank...both located on the left side of the bed.
Old Apr 15, 2017 | 05:24 PM
lasermike's Avatar
lasermike
Confusingly, I tend to use saddle to mean any tank outside of the cab. I do have an actual saddle tank on mine but it's clearly not from Ford. And it's got 3 or 4 gallons of 7 year old 2 stroke fuel in it. Very unlikely to burn, even with a match!
Michael
Old Apr 16, 2017 | 09:17 AM
march's Avatar
march
Just to make sure, are you reading the level on the correct tank? I'm going to try to attach a file for you. Ford changed which tank is considered "main" and which is "aux" over the years. This is from page 9 of the owners manual for 1978 trucks. "Main" is your midship tank.
I'll have to be more precise in my terminology so ND doesn't have to correct me.
File Type: docx
Old Apr 16, 2017 | 09:32 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
1. Beat/tazer the neighbor kids for touching you truck...now I know that really can't happen, I just typed what I was thinking. But WTH a neighbor kid might of put a water hose in there!!!
X2 on sounds like you could have a stuck valve and some how fuel went from one tank to the other.
I'd drain the one that you do not use, and is full of who knows what, then disconnect it from the valve. I'd drain the other if there is a chance it got a water hoes in it.
Get a locking vented or none vented what ever applies gas cap. Then I'd go talk to the neighbor kids dad.
78/79 duel fuel tanks frame switch-Duralast/Universal 3 port fuel selector valve used with SW48 toggle switch Part Number: FSV4
Old Apr 17, 2017 | 09:44 AM
xxkenny90xx
Wow thanks for all the replies, it seems unanimous that I need a new valve (and a tazer). For the record my truck has a front (main) tank that is long and skinny on the side of the bed, and a aux (rear) tank that is square and at the back of the bad. It did seem to stop the leak when I backed the truck up on an incline but I'll hold off on driving it until I do the valve.
D-rat
Sep 21, 2017 12:31 PM
Brokewhiteguy
Sep 4, 2014 08:04 PM
MarksA-C
13
Nov 27, 2011 06:38 AM
lahammer1
Jun 17, 2010 05:01 AM
FlaresideGlenn
Nov 15, 2004 03:48 PM
