Dizzy Rotor bounces?
No rollers or rockers included.
https://www.summitracing.com/parts/c...view/make/ford
Yes it is possible to change the valve springs with the head on. Just be sure to keep the piston at the top to not lose a valve. I did it once. A spring flew out of the tool out the garage and across the property. I walked around with a flood light and extension cord for ages to find it. I now pull the head to change springs.
I still recommend screw in rocker studs and at least comp stamped rockers. That requires pulling the head anyway.
There are many threads on how to change cams here have a loon around. If you have a specific question unanswered by them I'll help.
1. drain your coolant and oil
2. pull the rad, belts, valve cover, grille, fan, water pump pulley, pushrod cover, distributor, fuel pump
3. using a puller pull the balancer and remove the timing cover
4. remove the rockers, pushrods, and throw the lifters in the garbage
5. remove the intake and exhaust
6. roll the engine to topdead center and leave it
7. take off the 2 cam retaining bolts
8. pull the cam
9. press off the old gear, don't damage the plate or lose the small key
press the parts on the new cam
10. pull the head and have a machine shop and recondition the head while its off, new screw in studs, install valve springs and set to height according the card the came with the kit
11. clean the engine deck surface with fine sand paper on a flat bar of steel to clean it up
12. cover the cam lobes, bearing surfaces and lifters with the included lube
13. slide the cam in with gears lined up, drop in new lifters
14. install head, torque to specs in order
15. install pushrods, fuel pump, distributor at #1, timing cover, balancer, pushrod cover, water pump pulley, fan, rad, intake and exhaust.
16. adjust your valves one cylinder at a time. roll the engine over a 1/3 turn so the distributor points at the next cylinder and adjust that one.
17. fill break in oil and coolant
18. put on valve cover
19. start the engine and run for 20min at 2000-2500 rpm varying.
20. be sure the pushrods spin.
21. recheck valve lash
22. oil and filter change
23. good to go
I may have missed something off the top of my head.
8. pull the cam
23. good to go
you say check valves. All I am seeing to check is lash? Is this correct?
can I pull lifters with the head on? Do I use a magnet for this?
I am not pulling the head so I won't be doing a bunch of those steps... What kind of oil for break in?
is my set I linked to up top the right set? Can you point me to the rockers and studs you recommend?
Rockers are comp cams 1266-12Studs you can use ARP 134-7104, but the head must be pulled and sent to a machine shop to install them. If you already have pivot ball rockers you may be fine. I send bolt down rockers and they may have been what caused problems. The added lift and spring pressure may pull out press in studs. Up to you of you want to spend the cash for parts that can take the abuse or chance the stock parts. There is always the option of a small cam and leaving the stock springs etc on.
The lifters are behind the cover next to your distributor. Head can stay on. Pliers or a magnet will get them out then throw them in the garbage.
Checking valves , I probably meant lash.
I don't have the cash for everything but the rollers are at the top easy to do later. I just need the vehicle running for now. Its not a daily driver. Yet. I would like to get to that point but I am too occupied with work and school to get it there.
