2v or 4v heads????
Old Apr 13, 2017 | 08:23 PM
Keith Mitchell's Avatar
Keith Mitchell
2v or 4v heads????
Quick question.... I'm building a 360 into a 390 and im seeing a lot about 2v or 4v heads lately.... As a mechanic I've always used to 2v or 4v to describe number of valves per head, and as far as I know there isn't a 4v head for FE engines ... I've seen a few sites that sound like they are referencing a 2bbl or 4bbl carburetor... What exactly are they talking about and what are the differences in the heads?
Old Apr 13, 2017 | 11:45 PM
85e150's Avatar
85e150
In these engines it's 2 Venturi or 4 Venturi, meaning 2 or 4 bbl carbs.
There are no 4 valve FE heads. Even the SOHC and tunnel port heads, the two "most advanced" heads for the FE were both 2 valve heads.
In the realm of the 360 and 390 pickup engines, for any given year, the heads were the same on both engines. In cars, ditto the garden variety 428s and the two years of the 410 and the 390s. Even the 352 and 390 were the same in those years.
(other than performance models)
FE Cylinder Head I.D. and Application Chart
If you are building a stock to mild engine, stock "D2TE" casting number heads are just fine. The next step would be larger valves for those, and after that it's probably more cost effective to step up to aftermarket heads.
Old Apr 14, 2017 | 09:50 AM
Keith Mitchell
I figured it was in regards to the carburetor and not the heads which is why it was confusing seeing people say 4v heads... Thanks the answer
Old Apr 14, 2017 | 11:41 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
2v vs. 4v in Ford-land usually describes small-block heads (289/302/351W).
For the FE series, the big difference between 2bbl carb and 4bbl card was (usually) total compression which was done with the pistons. The heads were pretty much the same.
** Of course, there were some differences in certain FE engines in regards to the heads, but overall, 2v vs. 4v was not an "FE" thing for the most part.
Old Apr 16, 2017 | 08:50 AM
Destroked 450's Avatar
Destroked 450
Most times when we're talking about Ford engines and someone refers to 2 bbl or 4 bbl heads, they're usually talking about a 351 Cleveland, on occasion talk about the 69 351 Windsor 4 bbl heads will come up but no often.
If anyone referred to FE heads as 2bbl or 4bbl heads they got educated real quick.
71 Muddbugg
Jan 10, 2005 04:53 AM
Azguy54
May 9, 2004 07:54 AM
alleycat
Feb 26, 2004 02:08 PM
gtex
Sep 4, 2002 12:45 AM
66ford428
May 30, 2002 12:14 PM
