Debadging
Old Apr 12, 2017 | 08:48 PM
Oxfordbp's Avatar
Oxfordbp
Debadging
Best way to take the 6.7 powerstoke badging off doors? Heat gun and goof off?
Also want to take off he 4c4 stickers off the bed. Same process basically?
Thanks!
Old Apr 12, 2017 | 08:56 PM
UGA33's Avatar
UGA33
Badges would be a heat gun and some steady pressure. If that doesn't work, Hair dryer and fishing line would be your best shot. Goof Off/Goo Gone to remove any residue left behind. As for 4x4 decals, heat up and peel off with your finger nails.
If you get the two sided tape to the right temp, the residue will be non existent when the badge finally comes off.
Old Apr 12, 2017 | 09:10 PM
Pintabo's Avatar
Pintabo
Trailering
Fishing line to "saw" them off, then use a stripping wheel to remove all the glue.
Old Apr 12, 2017 | 09:56 PM
BII Plow Truck's Avatar
BII Plow Truck
Dental floss works too.
Old Apr 12, 2017 | 09:58 PM
Super-Truck's Avatar
Super-Truck
Fishing line to saw along the badges and once off use adhesive remover. Or you could use and eraser wheel to speed up the process.
Old Apr 13, 2017 | 01:05 AM
Oxfordbp's Avatar
Oxfordbp
Thanks guys!
Old Apr 13, 2017 | 07:20 AM
bushpilot's Avatar
bushpilot
Nice Thread!
Question: are both of the Door Mounted 6.7L & PowerStroke badges "stuck" on?
Question: are any of the door badges "pinned" on?
I've removed the FX4 stickers on the bed (warm 'em w/ a heat gun)
Old Apr 13, 2017 | 07:37 AM
Tic-Toc's Avatar
Tic-Toc
Front emblem - two cheesy nuts
Back emblem - stuck on
Side emblems - clipped - just pull carefully
6.7 and powerstroke door emblem - stuck on
Stuck on - a LITTLE heat (you will melt the plastic), dental floss. Then 3m adhesive removing wheel to take off the leftovers.
Tic-Toc's Avatar
Tic-Toc
Just pull off the 4x4 sticker on a warm afternoon.
Old Apr 14, 2017 | 10:49 AM
tuclai's Avatar
tuclai
For the Powerstrokes and 6.7 badge, I just used strong fish line to cut it through. This method will separate the emblem from the double sided tape which will still be on. I just used my fingers to rub the tape off and any residue left I used Meguiars rubbing compound to buff off by hand. Just make sure to use a side to side and up and down motion, dont pull towards you as it may break the emblems.
The side fender badges are held together by 4 clips if I remember, you pull slowly. On mine the metal clips separated from the plastic ears of the badge, when you noticed that pull carefully so you dont break the plastic ears.
The FX4 or 4x4 just use heat gun or hair dryer and start peeling.
I personally like the de baged and color matched look
Old Apr 14, 2017 | 10:59 AM
ERock62's Avatar
ERock62
Looks great!
Old Apr 14, 2017 | 01:33 PM
fuelpro's Avatar
fuelpro
What paint did you use on the chrome. I've painted chrome before and after a while it started to release. Thinking about using epoxy primer and 80 grit
Old Apr 18, 2017 | 11:41 AM
tuclai's Avatar
tuclai
I took the chrome parts off myself and had a body shop do the paint. They scuffed up the chrome first then used some adhesion promoter, then primer, then paint, then clear coat. Im not a fan of aftermarket paint jobs, since I dont think its ever as good as a factory paint job, but since these are not front facing like a grille or bumper I was ok with it. My front bumper came painted from factory and I had it clear bra immediately because I did not want paint chips.
Old Apr 18, 2017 | 11:43 AM
tuclai's Avatar
tuclai
Thanks, just waiting patiently for the lift.
Originally Posted by ERock62
Looks great!
Old Apr 18, 2017 | 12:12 PM
Tic-Toc's Avatar
Tic-Toc
The problem with painting over the chrome is it will peel. I am talking about the chrome itself from the plastic, not the paint from the chrome. If you scuff by hand you might be ok.
This has happened to mine, my dad's and a buddy now. We are ordering new parts and taking them to a chrome shop to have the chrome removed.
What I think is happening after playing around a bit. Is the heat from the friction using a rotating sander is magnified with the chrome. Then whatever make the chrome stick to the plastic is weakened. I did this lightly with a sander that had a scuff pad, then I peeled the chrome right off in chucks. Its wasn't that hard.
Just an FYI for those interested.
