Help with carb spacer
Old Apr 12, 2017 | 07:16 PM
Jakob94's Avatar
Jakob94
This is my first post to the forum, I just joined, and I'm stumped on this carburetor spacer that I pulled off the truck. I'm starting the process of restoring my grandfather's Farm dump truck which is a 1969 F350 with the 360 engine. The spacer was underneath the carburetor and one function of it was that it was connected to the coolant hoses that ran to the heater core in the brake booster on the back, but other than that I have no clue what other functions it serves or served. I'm just wondering what this is actually called, what it does, and if I can get parts to restore it?
Old Apr 13, 2017 | 12:23 AM
mrpotatohead's Avatar
mrpotatohead
That is a governor. I doubt this came as original equipment on an F-350. I've seen them on trucks and buses in the 600 to 700 series with medium duty and heavy duty engines.
Old Apr 13, 2017 | 06:01 AM
KOT390's Avatar
KOT390
Ha! That's awesome! Thanks Mrtaterhead for clearing that up. I had no clue what that was, never seen one in my life but when I saw the post I was curious.
KOT390
Old Apr 13, 2017 | 06:41 AM
Jakob94's Avatar
Jakob94
Smile
Yeah I kind of see thatnow. The flaps been taking off on that. I know that this was actually a model F351 so the gross vehicle weight was 10000 pounds instead of 8000. But when I go back I'll have to look to see if there is any Governor mounted on the engine.
Old Apr 13, 2017 | 10:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jakob94
C9TZ-12450-F .. Governor - 2800-4000 RPM / Marked: C9TF-12450-F / Obsolete
1968/69 F100 360 2V with IMCO / 1969 F250/350 360 2V with M/T
Old Apr 13, 2017 | 09:31 PM
Jakob94's Avatar
Jakob94
Thank you, thank you both for helping me out with figuring this part out. Could any one of you elaborate on what each connection or stick out is? Specifically​ the two plugged up hoses, the little pin that pokes into one of the ports, and if anything connects to the governor on the side? I know that's allot to ask. But let's me be able to find those connections, if at all in the engine compartment. I have ordered the shop manuals on CD and are about to be shipped.
Old Apr 13, 2017 | 09:57 PM
RichS2659's Avatar
RichS2659
Wasn't IMCO a company that provided propane conversions for gas engines in the 70-80's? Is that a propane metering device besides being a governor?
Old Apr 14, 2017 | 07:07 AM
mrpotatohead
If I remember correctly, the two black plastic lines went to an additional housing on the distributor.
Old Apr 14, 2017 | 09:59 AM
NumberDummy
IMCO = Improved Combustion Emission Control System, introduced in 1967. Three port distributor vacuum control valve threads into the thermostat housing.
Signmaker
Mar 15, 2019 02:52 PM
OldBlackCat
Aug 3, 2018 04:00 PM
ligito
16
May 1, 2018 11:09 PM
BarePaw
Apr 28, 2015 03:15 PM
Furyus1
Jan 30, 2010 01:26 PM
