95 Explorer stalls while idling
Old Sep 10, 2003 | 09:10 PM
weirton57's Avatar
weirton57
Maybe this might help
The Throttle Position (TP) sensor is a potentiometer that provides a signal to the PCM that is directly proportional to the throttle plate position. The TP sensor is mounted on the side of the throttle body and is connected to the throttle plate shaft. The TP sensor monitors throttle plate movement and position, and transmits an appropriate electrical signal to the PCM. These signals are used by the PCM to adjust the air/fuel mixture, spark timing and EGR operation according to engine load at idle, part throttle, or full throttle. The TPS is not adjustable.
Fig. 1: Typical Throttle Position (TP) sensor mounting on the throttle body
JockD
Mar 28, 2018 08:41 PM
Ewillard
Jul 11, 2015 10:40 PM
BroncoBilt
1978 - 1996 Big Bronco
Dec 28, 2014 06:15 PM
bdog813
Jul 12, 2014 09:03 PM
MR KROGOTH
22
Jan 27, 2014 09:38 PM
