6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 puking coolant..
Old Apr 12, 2017 | 12:01 PM
kenny adkins's Avatar
kenny adkins
Ok so i bought an 08 6.4l and two weeks into my ownership the oil cooler started throwing codes.. so I take it in and while the cab is off I had them delete the EGR, put HPS reinforced radiator hoses, sinister coolant filter, S&B intake, 5" straight pipe, head gaskets & ARP head studs, and one of the heads needed to be replaced. I get it back and it's making a swuealing noise I take it back to them for an up pipe job. I get it back AGAIN and now it's puking coolqnt as fast as I can fill it.. what could be causing the puking? There's no EGR coolers to go bad, and it has a new head with head gaskets and studs.. what else could even make it like like this? I would think blown head gasket would be the only way it would puke? Any help would be appreciated at this point.
Old Apr 12, 2017 | 04:54 PM
jimh425's Avatar
jimh425
Sounds like they did something wrong. What did they say what they think it is?
Old Apr 12, 2017 | 05:37 PM
DieselDenny's Avatar
DieselDenny
Subscribing. I just found a gallon on the garage floor.
Old Apr 13, 2017 | 01:06 AM
kenny adkins
I called them and they just told me the shop is full right now and they can't get me in yet.. but I drove the truck today and it didn't puke any but when I shut off the truck I can hear the reservoir bubbling and the coolant level rises up? I'm confused as can be on this and I'm hoping it's not another head gasket.
Old Apr 13, 2017 | 10:27 AM
jimh425's Avatar
jimh425
That sounds like maybe a thermostat or similar valve. Did they replace the coolant bottle cap?
Old Apr 13, 2017 | 02:26 PM
kenny adkins
the thermostat will make it puke coolant outbthe degas bottle? And yes I put a new cap on it and got less coolant loss but still coolant loss..
Old Apr 13, 2017 | 02:47 PM
jimh425's Avatar
jimh425
I think someone said that the 6.4 isn't supposed to have a thermostat. I did some looking and it seems that some people think it could be overfilled with coolant or have air trapped in the coolant system. Take a look at this thread.
Old Apr 13, 2017 | 03:06 PM
DieselDenny
6.4 has a stat. For my problem, just going to start with a new degass cap.
Denny
Old Apr 13, 2017 | 03:18 PM
DieselDenny
This is for the team.
I just got off the phone at the parts counter to order a degas cap.
Just so happens their tech was standing on the other side of the counter.
The Tech said that the stock caps were inadequately manufactured and could hold pressure way off the board resulting in upwards of 10 pounds more pressure than designed.
They corrected it with the new style. He said also the manufacturing date should be after 2012 on the package.
He also was burbbling about how many 6.4's come thru with leaking coolers and intrusion of seals into the oil system thru coolers because of the pressure.
Makes perfect sense to me.
Can't believe this expensive engineered engine could suffer catastrophic damage over a 12 dollar part.
Crackin a beer!!!
Heads up people (6.4 people) My cost, 12.22
Denny
Old Apr 14, 2017 | 11:09 AM
kenny adkins
Denny
I put the updated cap on the truck the day it started blowing it all out and it slowed it down but didn't stop it..
Old Apr 14, 2017 | 11:14 AM
kenny adkins
ok so the puking did slow down and even stop as of yesterday but the coolantblevel stil gets lower and lower everyday and the return line in the middle of the degas bottle bubbles when I shut the truck off?? I called the shop back again today and they told me they did not check the head before putting it back on the truck.. they just cleaned it and slapped it back on.. so chances are I have a head gasket blown already.
Old Apr 14, 2017 | 03:08 PM
DieselDenny
I'm thinking maybe a warped head Kenny.
I can't believe they didn't true it up before reinstalling.
That's like day one stuff.
Old Apr 14, 2017 | 04:47 PM
kenny adkins
Yeah I sold my 7.3 to buy this 6.4 thinking studs and a delete would be a fix all but now I see why everybody told me it was a bad idea -__-
Old Apr 16, 2017 | 03:56 PM
DieselDenny
Kenny, just an update, my problem is lower radiator hose at the block.
I'm going with the 249.00 blue hoses offered on Ebay with fittings, double o-ring style.
Mish wants 495.00. Really?!
Denny
Old Apr 16, 2017 | 11:58 PM
82_F100_300Six's Avatar
82_F100_300Six
Holy cow that is ridiculous for a radiator hose.
buckweet1980
Sep 23, 2019 04:29 PM
gerry p
Feb 25, 2012 07:32 AM
caere
Aug 13, 2010 03:34 PM
8525ford
Jul 27, 2009 11:16 PM
