'59 223 Rocker arm oiler tube
OK, so in my engine teardown I got just a little over-zealous in trying to remove the oiler tube from my 223 and it's now twisted and needs to be replaced.
I've done some basic searching and it seems this part is pretty hard to come by these days. Would it even be worth it to try and fabricate a replacement? Could I just use a similar size steel tubing with the correct bends?
1959 223 I-6 Rocker Arm Shaft Oil Tube
OK, so in my engine teardown I got just a little over-jealous in trying to remove the oiler tube from my 223 and it's now twisted and needs to be replaced.
1954/60 F100/600 223 I-6 / 1961 F100/600 223/262 I-6 / 1962 F100/600 223/262 I-6 before serial number 280,001 // 1954/59 223 I-6 Ford Passenger Cars.
EAA-6580-B .. Valve Rocker Arm Shaft Oil Inlet Tube / Obsolete
No Ford dealer or obsolete parts vendor has any.
B5A-6588-B .. Valve Rocker Arm Shaft Oil Outlet Tube - approx. 12 13/16" O/A length / Obsolete
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 5 = 800-476-9653.
FOWL1
31
03-07-2023 10:14 AM
Highboy4x4
08-13-2016 11:29 AM
P38fighter
06-13-2015 01:34 PM
