Truck shut down while driving
Old Apr 11, 2017 | 09:23 PM
cookingguy's Avatar
cookingguy
So I am out of town about 120 miles from home on a job. I was driving down the mountain road to the store and my tuck just shut down. Lucky for me I was able to get into a turn out. So I try to start the truck and it will not fire. I check for codes I am getting p2614, p2617 so I was able to clear the codes and get back to the house I am staying in. What is going on with my tuck. Oh ya the code did not come back on in the 15 min drive to the house.
​​​also just finished up doing a y pipe and my egr o ring so I and the intake and all that off.
Old Apr 11, 2017 | 09:42 PM
Tideman's Avatar
Tideman
P2614 P2617 cam/crank sensor. Check sensor wiring you probably have a short. You can wiggle around the drivers side wiring harness and it will go away until it shorts again and it may not do it again.
Old Apr 11, 2017 | 09:44 PM
cookingguy's Avatar
cookingguy
Which driver's side harness? The ficm?
Old Apr 11, 2017 | 09:48 PM
Tideman's Avatar
Tideman
It is in the same harness. When you did the work on it you pinched or knocked something loose. Just check FICM plugs. By it cranking back up it tells me something is loose. Sensors are still good.
Old Apr 12, 2017 | 08:21 PM
78fordman's Avatar
78fordman
excessive cranking will throw cam and crank codes. When the truck shut down, do you remember if the wait to start light cycled on like when you turn the key on? Also do you get a fan speed sensor input or is it 0?
PSDNovice
Aug 23, 2021 02:25 PM
cookingguy
Apr 14, 2017 05:03 AM
bullydog831
Dec 6, 2016 04:32 PM
kornfanjoe
Mar 13, 2013 06:09 PM
aocabrown
Feb 13, 2008 05:34 PM
