headlight bulbs
Old Apr 12, 2017 | 09:13 AM
rwilimo's Avatar
rwilimo
I recently tried Race Sport brand, the beam pattern was poor, the plugs did not connect well without modification and they would blink and go out with the engine running, fine with engine off. Very disappointed, I am considering changing over to the factory led's
Old Apr 12, 2017 | 11:25 AM
Kevin611's Avatar
Kevin611
Originally Posted by Oxfordbp
How long have you run them?
I have ran them for 3 years now never a problem, fit good, no fans for cooling also.
Old Apr 12, 2017 | 11:51 AM
crewzer's Avatar
crewzer
Exclamation
I must admit that the units with cooling fans cause me concern about longevity...
Regards,
Jim / crewzer
Old Apr 12, 2017 | 01:16 PM
jimzpsd's Avatar
jimzpsd
LOL, next will be liquid cooling.
Old Apr 12, 2017 | 03:30 PM
GoDuke1's Avatar
GoDuke1
I'm glad you posted that video. Everyone I've seen before this one they have taken the grill completely out of the truck and removed the headlamp assembly's. If it can be done this way that will simplify the installation
Old Apr 12, 2017 | 06:55 PM
ahayter's Avatar
ahayter
4th Gear
I would like to know if the daytime running lights worked after you upgraded to the H13 LED bulbs and if you had to install the resistors?
Thanks
Albert
Old Apr 12, 2017 | 07:21 PM
vavtx's Avatar
vavtx
I posted about this a couple of times. I replaced mine with Amazon ones. Work much better, everything works normal, never been flashed by oncoming traffic. I did not remove the grill. I just reached down and changed them. About 10 mins per side. They were plug and play.
IndySilverAnny
1997 - 2003 F150
Jan 31, 2019 12:53 PM
rangerbob406
Nov 14, 2015 12:56 PM
Ford'05HG
Jan 25, 2013 07:50 AM
HookedOnFuel
Nov 26, 2007 10:47 PM
Goble18
1978 - 1996 Big Bronco
Feb 3, 2004 02:50 PM
